Helen Palmer Posted May 20, 2023 Share Posted May 20, 2023 (edited) I am trying to create rows of plants drawn in Landmark with the Plant under poly edged spaced mode. I can apply the fill across plant grouping but it only works correctly if the line is straight - if I have any corners or bends the fill is just extended across that bend. Previously I have done this action with no problem on a variety of drawings but in 2023 there seems to be a bug unless I am doing something wrong. Very frustrating! Running landmark 2023 SP5 (which made no difference to SP4 with this problem) on Mac Ventura 13.3.1. Everything is up to date. screenshot attached. Helen Edited May 20, 2023 by Helen Palmer Quote Link to comment
loretta.at.large Posted May 20, 2023 Share Posted May 20, 2023 I've been having a similar issue. Quote Link to comment
Jonathan Pickup Posted May 20, 2023 Share Posted May 20, 2023 I'm running Vectorworks 2023.SP5 and i'n not having that issue. Does this also occur in a new blank file? What do you see when you select the plants and activate the Reshape tool? Quote Link to comment
Tom W. Posted May 21, 2023 Share Posted May 21, 2023 20 hours ago, Helen Palmer said: Previously I have done this action with no problem on a variety of drawings but in 2023 there seems to be a bug unless I am doing something wrong. See: Quote Link to comment
loretta.at.large Posted May 22, 2023 Share Posted May 22, 2023 My issue has mostly been with groups of plants using triangular array. Sometimes when I select "apply fill across plant grouping," it looks fine... and other times it just doesn't. Attached is a screenshot as well as my file if anyone wants to check it out. Apply fill across plant grouping.vwx Quote Link to comment
DSmith2300 Posted May 25, 2023 Share Posted May 25, 2023 Some plant symbols will work for me, some won't. See screengrab below I've definitely ticked that box, but the red ones refuse to do it. Quote Link to comment
