Extract Brick Textures
FranAJA
Good afternoon,
I am trying to extract textures from vectorworks created with "Brick" shader in renderwork texture but the only thing i can extract are the single component of the texture (single brick or single line of mortar).
When I import the model into Twinmotion, does not show any texture created by brick shader so i was trying at least to make one by me.
Is it possible to export a full (let's say 3meters x 3 meters) texture from vectorworks even if created with "Brick" shader ?
Regards
I don't think you can directly export those textures, but you could render a 3m x 3m object and use the resulting image as a basis to build a texture in TwinMotion.  That being said, there are tons of very good PBR brick textures to be found on the internet that have all the various shaders needed for realism.
