Getting Handle to Light Position Obj
If I can get the name of a Light Position Obj (LPO)(Hanging Position), how can I get a handle to the LPO.  Is the only option to cycle through all the LPOs until I find a match using a "ForEachObject() and GetRField(LPO, 'Light Position Obj', 'Position Name')?  GetObject(name) won't work, because the name is not put in the "Name" field at the bottom of the LPO instance's OIP.
Typed in the forum and not tested, but you should get the idea.
Procedure Test;
Var	HandleToLPO	:Handle;
Procedure Execute(Hd1:Handle);
Begin
 HandleToLPO:=Hd1;
End;
Begin
 ForEachObject(Execute,('LightPosition Obj'.'Position Name'='YourLPONameHere'));
 Message('The Handle to the LPO is: ',HandleToLPO);
End;
Run(Test);
Using " 'LightPosition Obj'.'Position Name'='YourLPONameHere' " as a criteria is new and exciting.  I was expecting to have to use a selection criteria like " ((R IN ['AP Light Position Obj'])) ".  I can simplify many things by specifying record field values in the callback.   Off to test now.
