E|FA Posted May 11 Share Posted May 11 I started this thread to move the data vis discussion away from the hijacked: https://forum.vectorworks.net/index.php?/topic/107553-styled-door-and-window-classes-in-remodel/ I created a custom Record Format with New/Existing/Demo (also "replace" but I think I might remove that). I built the existing model and attached the Existing record to everything I could (Doors & Windows need to be selected separately from the Walls they're inserted in and Records attached to them separately). I've trimmed the Walls that will be demolished and changed their record to Demolish. So far so good. Theoretically, EVERYTHING I add to a Design Layer from this point forward should get the "New" record. The Record Format is set to default to New. Can I set it to auto-attach to everything I draw? Quote Link to comment
Tom W. Posted May 11 Share Posted May 11 As per the other thread you can set up data mapping in the Data Manager so that certain records are attached to certain objects based on class. Quote Link to comment
E|FA Posted May 11 Author Share Posted May 11 Thanks. Time to read up on the Data Manager. I tried once before and got confused. Fingers crossed (and VWU, etc) Quote Link to comment
Tom W. Posted May 11 Share Posted May 11 See attached sample file. I have created a 'Phase' Record + a 'Phase Wall' Wall Style that is set to go into the 'Wall-Main' class on insertion. I have set up a data mapping in the Data Manager that makes it so that every object created in or assigned to the 'Wall-Main' class will have the 'Phase' Record automatically attached to it. The default is currently 'Existing' but this can be changed in the Data Manager, or in the Record of course if you're happy for all mappings to be the same. This is about ALL I know how to do with Data Manager! Happy to give you the steps. I didn't find much useful info out there. Phase by Record.vwx 1 Quote Link to comment
E|FA Posted May 11 Author Share Posted May 11 @Tom W. Thanks for getting me started. I see how you have attached the record by class. Looks like what I'm proposing to do is to attach a record to most of my classes (e.g. don't need it on annotations), plug in objects, symbols, etc. Quote Link to comment
E|FA Posted May 12 Author Share Posted May 12 FYI, there’s a VWU Data Manager video at https://university.vectorworks.net/mod/overview/view.php?id=5015 As I work through this, I’m realizing there’s no need to mark objects that are New. Once Existing and Demolition are marked with a record, by default everything else (whether the Record is attached or not) is New. I think I was overcomplicating things. Quote Link to comment
Tom W. Posted May 12 Share Posted May 12 8 minutes ago, E|FA said: FYI, there’s a VWU Data Manager video at https://university.vectorworks.net/mod/overview/view.php?id=5015 Yep saw that live at the time but was a bit over my head if I'm honest... I am not so interested in the IFC side of things. 9 minutes ago, E|FA said: As I work through this, I’m realizing there’s no need to mark objects that are New. Once Existing and Demolition are marked with a record, by default everything else (whether the Record is attached or not) is New. I think I was overcomplicating things. I don't totally follow this. If the Record is not attached to new objects then yes I can see that they are by default not existing + not demolished, but presumably if the Record is attached then those objects will be defined by whatever the default value is for the Record? Plus is there not a benefit to having 'New'-by-Record objects in the file for Data Vis purposes? 1 Quote Link to comment
jeff prince Posted May 12 Share Posted May 12 9 hours ago, Tom W. said: Plus is there not a benefit to having 'New'-by-Record objects in the file for Data Vis purposes? I think so as it allows you to quickly change graphics for various exhibits and brings the workflow into a consistent behavior. 1 Quote Link to comment
Tom W. Posted May 12 Share Posted May 12 2 minutes ago, jeff prince said: I think so as it allows you to quickly change graphics for various exhibits and brings the workflow into a consistent behavior. Yes precisely Quote Link to comment
E|FA Posted Wednesday at 04:28 PM Author Share Posted Wednesday at 04:28 PM Linking back to the original thread for a response from @Luka Stefanovic regarding separate layers for demo/existing: Quote Link to comment
