td4stage Posted October 16, 2001 Share Posted October 16, 2001 Ok, I figured out how to create a multi cirucit cyc unit! Thanks Kacey! Now when I create a lighting key the cyc unit comes up in its component pieces instead of one "unit". How can I fix this? Thanks, Pat Immel Quote Link to comment
kmoore1 Posted October 17, 2001 Share Posted October 17, 2001 quote: Originally posted by td4stage: Now when I create a lighting key the cyc unit comes up in its component pieces instead of one "unit". How can I fix this? There is no way to "fix" this. You can manually edit the key to instrumentation and insert the correct unit, but you will have to do this each time you re-create the key. Multi-circuit instruments are on my hit list for improvements. I'm working on improving the whole situation with multi-circuit units. Easier insertion, accurate inventory counts, and the key are all on the list. ------------------ -- Kevin Moore --------------------- Product Manager VectorWorks SpotLight --------------------- Quote Link to comment
td4stage Posted October 17, 2001 Author Share Posted October 17, 2001 Thanks for your attention Kevin!!! Pat Quote Link to comment
