Dialog to select objects
First of all, thanks to the community I came quiet far with the forums content.
somehow I can’t find something
to build a dialog to select objects.
I would be glad if someone can point me to the right direction?
Thanks a lot for your answers.
I see. I need to explain a little more.
So far iam trying to build a Tool wich creates simple buildings from different Polygons.
I think it could speed up urbanplanning routines alot.
As example:
It grabs simple 2D polygons from the calsses "building basement" , "building mid part" and "building top part"
then extrudes the polygons and stack them as floor levels to an simple building.
So far not a problem.
Id like to run the script and select different sets of buldings to set up different settings for numbers of floors etc.
Therefore id like to have an dialog to select objects.
In future i'd like beeing able to activate each buidling and change the settings for exmaple the amount of floors for each within the OIP
