tbexon Posted April 19, 2023 Share Posted April 19, 2023 (edited) Hi All So I'm trying to add functionality into an already existing Event based PIO that allows the user to click a button in the OIP and choose a Lighting fixture on the drawing, and get some information from it. The bit I'm struggling with is finding a way to use vs.GetPt() (or any similar user interactive command) within a Python Event based plug in object. The structure of the Plug In is pretty standard, the main outline of which is below. def makeOIP(): global objectHand , BackgrdColourDict, ForeGrdColDict, position_note_rec_name ok, objectName, objectHand, recordHand, wallHand = vs.GetCustomObjectInfo() theEvent, theEventData = vs.vsoGetEventInfo() # Gets Object Event info if theEvent == tb.Constants.kObjOnInitXProperties: # If the event is the initialisation of the object ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference, True) # Allows for creation of custom OIP ok = vs.SetObjPropVS(tb.Constants.kObjXPropHasUIOverride, True) # Custom OIP Overrides standard UI ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference,True) # Enables preferences menu for PIO ok = vs.SetObjPropVS(tb.Constants.kObjXHasCustomWidgetVisibilities,True) vs.vsoInsertAllParams() # Inserts all Parameters floato OIP result, scaleWidID = vs.vsoPrmName2WidgetID('','Scale') thisDoesNothing = 0 result = vs.vsoAppendWidget(tb.widgetTypes.WidgetButton, link_pos_button_id,'Get Position Info', thisDoesNothing) if theEvent == tb.Constants.kObjOnWidgetPrep: WidgetPrep() # Sets Info within the OIP if theEvent == tb.Constants.kObjXPropPreference: defaultVals = {} # Creates blank Dict for default vals MakePropertiesDialog() if theEvent == tb.Constants.kObjOnObjectUIButtonHit: # If the event is a button being pressed if theEventData == link_pos_button_id: # If the Button Pressed is Link Position Button link_to_hp() # Runs if theEvent == tb.Constants.kResetEventID: # If Object is reset init() # Creates the Object When the button is pressed it calls a function, link_to_hp() def link_to_hp(): vs.SetObjPropVS(tb.Constants.kObjXHasCustomWidgetVisibilities, False) # Sets widget custom visibility to false try: vs.GetPt(PickPointCallback) except Exception as e: vs.AlrtDialog(str(e)) h, p = 0,0 Fix_H = vs.Rpstr_GetValueStr(tb.ValueStrings.FixtureHandle_TempValString,False) # Stores the Fixture handle as a Vectorworks Value String vs.Message(str(Fix_H)) vs.SetObjPropVS(tb.Constants.kObjXHasCustomWidgetVisibilities, True) # Sets widget custom visibility to True def PickPointCallback(pt): vs.Message('X: ', pt[0], 'Y: ', pt[1]) Fix_H = vs.vstGetPickObject(pt[0],pt[1]) # Stores the fixture handle as a VWX Value string for retrieving later after GetPt callback has been run vs.Rpstr_SetValueStr(tb.ValueStrings.FixtureHandle_TempValString,Fix_H) vs.SetObjPropVS(tb.Constants.kObjXHasCustomWidgetVisibilities, True) # Sets the Custom Widget visibulites back to True The main issue I'm having is that whenever I press the button, the GetPt cross hairs appear, I'm able to select a point, but then Vectorworks crashes, with no error message. I understand the main issue is that the Python function GetPt will not block execution, so I need to use the callback function. However I am still getting the same results. From a fair amount of searching of the forums, I have found several suggested solutions such as @Paolo suggestion in this thread to disable custom widget visibilities whilst vs.GetPt is running, however sadly this does not seem to have any affect. I've seen suggestions that there cannot be any functions inbetween the GetPt call, purely as a test I've tried adding a vs.GetPt() at the end of the of the file, with some very dodgy logic to allow it only to run after the UIButton has been hit. E.g: makeOIP() if runGetPt: vs.GetPt(PickPointCallback) Still no improvement, still crashes with no error. I've tried completely emptying the PickPointCallback, in case it was something inside there, but still no change. Does anyone have any suggestions as to how to achieve this kind of functionality within a Python Script? Surely people have managed to find a way around this? @Vlado @JBenghiat @twk Thank you in advance! Edited April 19, 2023 by tbexon Quote Link to comment
DomC Posted April 19, 2023 Share Posted April 19, 2023 Also tried to solve that issue. But without a big success. You can run the complete python as a callback of GetPt. But Nested callbacks are not possible. So just one click can be done. My Workflow is to create a main script as a Vectorscript. I collect the clicks and user interaction and then run the python script inside this script. Also it is possible to run several python scripts inside the pascal wrapper. So far no better solution I can see. It gets two clicks in the drawing and draw a preview rectangle. Then save the result in the value reprository, where the python script after that can load the data. It you want to pause somewhere your python script and make a user interaction this workflow is not possible. Example for the Pasca-Script that calls the python script: PROCEDURE Reshape; VAR h1, h2, h3 :HANDLE; scriptName, values2python : STRING; py, res: BOOLEAN; s: DYNARRAY OF CHAR; pt1, pt2 : POINT; pt, pt_tl, pt_br : POINT; plan_rotation : REAL; FUNCTION TempToolCallback(action, msg1, msg2 : LONGINT) : LONGINT; BEGIN TempToolCallback := 0; CASE action OF 3: BEGIN {kOnToolDoSetupEventID} vstSetHelpString ( 'definiere rechteckigen Umformbereich auf' ); END; 103 : BEGIN {kToolDrawEventID} vstGetCurrPt2D( pt.x, pt.y ); pt_tl.x := Min(pt.x, pt1.x); pt_tl.y := Max(pt.y, pt1.y); pt_br.x := Max(pt.x, pt1.x); pt_br.y := Min(pt.y, pt1.y); vstDrawCoordLine( pt_tl.x, pt_tl.y, pt_br.x, pt_br.y ); vstDrawCoordRect( pt_tl.x, pt_tl.y, pt_br.x, pt_br.y ); END; END; END; BEGIN plan_rotation := GetPrefReal(93); IF (plan_rotation > 0) THEN BEGIN AlrtDialog('Dieser Befehl funktioniert nicht in der Planrotation'); END ELSE BEGIN GetPt(pt1.x, pt1.y); RunTempTool( TempToolCallback, FALSE ); {using $ as Delimiter, because in Germany comma is reservated for decimal seperator} Rpstr_SetValueStr('values2python', Concat('(',Num2Str(6, pt_tl.x),'$',Num2Str(6, pt_tl.y),')','$','(',Num2Str(6, pt_br.x),'$',Num2Str(6, pt_br.y),')')); res := GetScriptResource('Subscript', s, py); PythonExecute(s); END; END; RUN(Reshape); 1 Quote Link to comment
Pat Stanford Posted April 19, 2023 Share Posted April 19, 2023 This has been discussed here (probably more than once.) The issue as I understand it is that Python has no way to "pause" execution while waiting to run the script. Dom seems to have given you good information. The Function Reference has a little bit of information about this. https://developer.vectorworks.net/index.php/VS:GetPt Good luck. Quote Link to comment
DomC Posted April 19, 2023 Share Posted April 19, 2023 It looks for interaction with the VW API it would need a very different kind if integration of the python language or additional APIs which are able to communicate with the python script. Which maybe needed a very big effort or would not pay out the effort. I think the reason it not, that python can't pause. If i draw an object and then get after that some informations from that object, somehow the object was created in Vectorworks (not drawn, but minimum defined). So The python script here waits for the Object created by the VW binary and so i think it could be possible the python script also can await the user interaction. So I guess it user interaction may be is not technically limited because of python itself. Quote Link to comment
Pat Stanford Posted April 20, 2023 Share Posted April 20, 2023 I agree. It is not a limitation of Python, but a limitation of Vectorworks implementation of Python. But whatever it is it is inconvenient. 😞 Quote Link to comment
tbexon Posted April 20, 2023 Author Share Posted April 20, 2023 Thanks Dom & Pat, I was worried this may be the case. Thank you for your suggested solution Dom, unfortunately because I'm only looking to get user input when a button is clicked not on script initialisation, the only way I could see to implement this is to rewrite the base code for building the PIO in Vectorscript, and then call multiple python scripts at appropriate points. Given that this Plug-In is over 2000 Lines of Python, I just don't see the work required to implement this as a reasonable option for the functionality gain. I'd be curious to see what is stopping this functionality from being implemented within the Python side of Vector script, Python itself as a programming language definitely has tools to support this. From a personal perspective it certainly would be a big benefit to some of my tools! Quote Link to comment
tbexon Posted April 23, 2023 Author Share Posted April 23, 2023 So thanks to the wonderful @VladoI have managed to get this working! There is a bug with developer mode that was causing the crash. Disabling developer mode, so that the script didn't run twice each time solved the crashing issue. Below is an explanation of my process, and what I understood is happening based on Vlados Explanation to me. Working with a Event Enabled Plug In Object, use the below template. When the button in the OIP is clicked, the ButtonClick() function is called. Within this function we call the vs.GetPt() command, passing a function as an arguement (in this case PickPointCallback). The way I understand what's happening is: When you run GetPt, it effectively restarts the script, clearing out all your code, and JUST runs whatever code is within the PickPointCallback function. Hence why any variables you may try and call or save won't affect anything outside of the function. To get around this, within the PickPointCallback we can save whatever values we wish to the Value Repository, which will temporarily save them into the documents session. I am saving 2 Values. Firstly a string containing the Co ordinates the user selected. The second is a bool indicating that the GetPt has been called but not handled. The reason for this is that once the GetPt call has been made the PIO won't automatically reset. We need to manually send it a reset event using vs.ResetObject(objectHandle). The reason i'm using the 'newFixtureBool' is because otherwise the main Init code won't know whether it's running after the UIButton has been pressed, or from some other Reset Event. There are other approaches, you don't necessarily need to use a Bool to track whether the button has been hit or not, it really depends on your specific project. Hopefully this is of help to someone, if anything is unclear, please do just ask, and I will do my best to help! Once again massive thanks to Vlado for figuring this out, and sending me on the right path! def makeOIP(): global objectHand , BackgrdColourDict, ForeGrdColDict, position_note_rec_name ok, objectName, objectHand, recordHand, wallHand = vs.GetCustomObjectInfo() theEvent, theEventData = vs.vsoGetEventInfo() # Gets Object Event info if theEvent == tb.Constants.kObjOnInitXProperties: # If the event is the initialisation of the object ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference, True) # Allows for creation of custom OIP ok = vs.SetObjPropVS(tb.Constants.kObjXPropHasUIOverride, True) # Custom OIP Overrides standard UI ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference,True) # Enables preferences menu for PIO ok = vs.SetObjPropVS(tb.Constants.kObjXHasCustomWidgetVisibilities,True) vs.vsoInsertAllParams() # Inserts all Parameters floato OIP result, scaleWidID = vs.vsoPrmName2WidgetID('','Scale') thisDoesNothing = 0 result = vs.vsoAppendWidget(tb.widgetTypes.WidgetButton, link_pos_button_id,'Get Position Info', thisDoesNothing) if theEvent == tb.Constants.kObjOnWidgetPrep: WidgetPrep() # Sets Info within the OIP if theEvent == tb.Constants.kObjXPropPreference: defaultVals = {} # Creates blank Dict for default vals MakePropertiesDialog() if theEvent == tb.Constants.kObjOnObjectUIButtonHit: # If the event is a button being pressed if theEventData == link_pos_button_id: # If the Button Pressed is Link Position Button ButtonClickFunction() # Runs the GetPt Command vs.ResetObject(objectHand) # Resets the Plug In object if theEvent == tb.Constants.kResetEventID: # If Object is reset init() # Creates the Object makeOIP() def ButtonClickFunction(): """ Prompts the user to select a point on the drawing, and then calls the PickPointCallback function with the co ordinates for the user specified location as an arguement :return: """ try: vs.GetPt(PickPointCallback) # Prompts user to select a point on the drawing except Exception as e: vs.AlrtDialog(str(e)) h, p = 0,0 def PickPointCallback(pt): """ Callback function used in GetPt call to allow user to select :param pt: XY Co ords user selects :return: """ # Stores the fixture position as a VWX Value string for retrieving later after GetPt callback has been run vs.Rpstr_SetValueStr('tb__PositionLoc',str(pt)) vs.Rpstr_SetValueBool('tb__newFixtureBool',True) def init(): """ Runs whenever object reset event is called :return: """ NewFixH_bool = vs.Rpstr_GetValueBool('tb__newFixtureBool',False) Fix_H = vs.Rpstr_GetValueStr('tb__PositionLoc', False) # mGets the saved fixture handle if NewFixH_bool: # If the GetPt call has been made, but not handled SetPositionData() # Gets the saved GetPt data and do whatever you would like with it 3 Quote Link to comment
Vectorworks, Inc Employee Vlado Posted May 1, 2023 Vectorworks, Inc Employee Share Posted May 1, 2023 On 4/23/2023 at 8:03 AM, tbexon said: There is a bug with developer mode that was causing the crash. FYI, I found the bug and it will be fixed in Vectorworks 2024. Then the 'developer mode' option would not cause crash in these python-execution-suspend situations. 3 Quote Link to comment
twk Posted May 3, 2023 Share Posted May 3, 2023 @tbexon, you're a genius, I kept crashing previously, regardless of the developer mode on or off. The only thing that was missing from my code, was the reset object_hand call. Also, what is happening here: if theEvent == tb.Constants.kObjXPropPreference: defaultVals = {} # Creates blank Dict for default vals MakePropertiesDialog() don't think I've ever use the kObjXPropPreference constant in my plugins Quote Link to comment
tbexon Posted May 3, 2023 Author Share Posted May 3, 2023 (edited) I'll be honest I've just gone back over my template, and I've no idea why I'm using kObjXPropPreference... It's been a couple of years since I made that template. But certainly in terms of functionality it appears to work the same as kObjOnInitXProperties. (though I'm sure there is a difference) maybe @JBenghiat can shed some light). But basically within that call i'm just building the preferences dialog, and setting default values Edited May 3, 2023 by tbexon 1 Quote Link to comment
twk Posted May 5, 2023 Share Posted May 5, 2023 (edited) Hmm have you tried using these outside of plugins? The same code flow for me crashes vw. I'll post back with code soon Edited May 5, 2023 by twk Quote Link to comment
twk Posted May 5, 2023 Share Posted May 5, 2023 This simple script (outside of using plugins) crashes vw. Can someone else confirm? @Vlado, what am I doing wrong here? import vs h = vs.FSActLayer() def callback(pt1, pt2): vs.AlrtDialog(f'pt1: {pt1}, pt2: {pt2}') vs.GetRect(callback) Quote Link to comment
tbexon Posted May 5, 2023 Author Share Posted May 5, 2023 Have you definitely got developer mode disabled? For me, I found it had somehow got enabled system wide in the VWX preferences menu. Quote Link to comment
twk Posted May 5, 2023 Share Posted May 5, 2023 Nope, developer mode is disabled. Are you saying this works for you? Doesn't crash? Quote Link to comment
tbexon Posted May 5, 2023 Author Share Posted May 5, 2023 I’m on site today, but I’ll try and check over the weekend when I’m back at my PC! Quote Link to comment
twk Posted May 5, 2023 Share Posted May 5, 2023 Found the issue. I develop in the PyCharm IDE. When I'm doing rapid testing, I just run the Import/Run Script Command in Vectorworks and point to the py file. Which effectively runs the python script in Vectorworks. 99% of the time it works, except for these interactive functions I've just found out. However I can still develop in PyCharm, and rapid test, but I need to create a script resource in Vectorworks, and have the script hold the import functions call pointing to that py file/function from here. Then it works. Will submit a ticket Quote Link to comment
Vectorworks, Inc Employee Vlado Posted May 5, 2023 Vectorworks, Inc Employee Share Posted May 5, 2023 3 hours ago, twk said: runs the python script in Vectorworks. 99% of the time it works, except for these interactive functions I've just found out. Yep, I reproduced it too. Same problem but in the file execution, and thus not affected by the debug-mode option. Will be fixed in Vectorworks 2024. Thank you @twk! 1 Quote Link to comment
JBenghiat Posted May 10, 2023 Share Posted May 10, 2023 On 5/3/2023 at 2:44 AM, twk said: @tbexon, you're a genius, I kept crashing previously, regardless of the developer mode on or off. The only thing that was missing from my code, was the reset object_hand call. Also, what is happening here: if theEvent == tb.Constants.kObjXPropPreference: defaultVals = {} # Creates blank Dict for default vals MakePropertiesDialog() don't think I've ever use the kObjXPropPreference constant in my plugins This is the event raised when VW requests a preferences/settings dialog for the PIO. By default, this is basically just a floating version of ObjInfo, but if you set ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference, True) # Allows for creation of custom OIP You can handle the event and show a custom dialog. The Door, Window, and Data Tag insertion tools are all an example of this. 2 Quote Link to comment
Nik Posted May 18, 2023 Share Posted May 18, 2023 @twk could you post an example of what you mean On 5/5/2023 at 8:10 AM, twk said: Found the issue. I develop in the PyCharm IDE. When I'm doing rapid testing, I just run the Import/Run Script Command in Vectorworks and point to the py file. Which effectively runs the python script in Vectorworks. 99% of the time it works, except for these interactive functions I've just found out. However I can still develop in PyCharm, and rapid test, but I need to create a script resource in Vectorworks, and have the script hold the import functions call pointing to that py file/function from here. Then it works. Will submit a ticket I'm wondering if the issue I'm having here is related: Quote Link to comment
twk Posted May 19, 2023 Share Posted May 19, 2023 I select the Import>Script from file option, when I'm doing rapid testing. (I have it setup as a right-click context menu command as well) Quote Link to comment
