Michael Kanasink Posted April 17 Share Posted April 17 I use Vectorworks for Exhibition Design. Typically I have used it to draw plans and elevation in 2D and only used 3D models for casework. I want to start using 3D for all of the design work but have been hesitant mainly because I don't want to do redundant labeling of the art. I can typically work with over 100 art objects, all that require me to display some basic label information, so a streamlined process is key. That is easy to manage in a 2D plan, but I would like to be able to show renderings of the gallery as well without making a 2D and a 3D model, which is how I have been working up until now. This is obviously an inefficient way of working. Optimally, I feel like would be great to be able to place a flat artwork image on the model wall that shows as just an image in render mode, but displays graphically with a symbol with a label in plan view. Can anyone point me to a tutorial on how to set this workflow up or give some very basic instruction on where to start? 1 Quote Link to comment
Kevin McAllister Posted April 17 Share Posted April 17 I think I would make each artwork a symbol with an attached description record. Then you could easily label them in any view with a data tag that pulls the description from the record. It would take some initial time to input, but then it's fairly easy to maintain. Kevin 2 Quote Link to comment
EAlexander Posted April 17 Share Posted April 17 I approach this kind of thing with Hybrid Symbols. A hybrid will show 3d when in any perspective or orthogonal view, but 2d when in top/plan view. Kevin's suggestion of Records will help you add additional data to this idea. When you select 3D and 2D at the same time and then make a symbol - it automatically creates a Hybrid. Basic tutorial here: 2 Quote Link to comment
Kevin McAllister Posted April 18 Share Posted April 18 4 hours ago, EAlexander said: I approach this kind of thing with Hybrid Symbols. ^ this definitely. My symbols often start out as just 3d but usually become hybrid at some point...... Kevin 1 Quote Link to comment
BartHays Posted April 18 Share Posted April 18 A few of us have started a user group specifically for people who use VectorWorks for Museums (or similar Projects). This would be a great topic for our group and we can share some examples of how others have done similar tasks. We are very informal with a wide variety of experience levels. We met about one a month. If you are interested message me directly. Bart 2 Quote Link to comment
