Gregi Posted April 17, 2023 Share Posted April 17, 2023 Hello I'm working on a PIO with Styles. The PIO is a path object, so there's a profile and a path-group. If i would like to get the profile group "by style", i need a way to change the profile in the symdef - but how? I think it has to be done with one of those functions, but what's the difference between those two? def vs.vsoGetPluginStyleSym(): return hSymDef def vs.GetPluginStyleSymbol(hObject, hSymDef): return (BOOLEAN, hSymDef) Quote Link to comment
MullinRJ Posted April 18, 2023 Share Posted April 18, 2023 Hello @Gregi, Though I haven't used either command it appears the first, vs.vsoGetPluginStyleSym(), is used to reference itself and return the Symbol Definition linked to its STYLE definition. Its description says: "Allow an object to use its own implementation in creating and maintaining a plugin style." It must be used inside the PIO code, as indicated by the first three letters in the command name "vso". The second command, vs.GetPluginStyleSymbol(), appears to be used outside a PIO, as in a script that queries PIO objects, and it will return TRUE if the object is STYLED, and FALSE if it isn't. If it returns TRUE, it will also return a handle to the symbol that's used to define its STYLE. The best way to see what they do is to try them in simple scripts. Place a STYLED PIO in a drawing and write a short script with: Boo, SymHnd = vs.GetPluginStyleSymbol(FSActLayer) to see what it returns. Message out the boolean result, and the object type and symbol name of the returned handle. The vso command will require more setup to test its functionality, but if you are developing a STYLED PIO, place vs.GetPluginStyleSym() in your PIO script and set an AlrtDialog() with the object type and symbol name of the returned handle to see what comes out. You may have to move the command around so that it executes in the proper event and at the proper time. If this is not clear, wait for better answers. I'm sure they are out there. Raymond Quote Link to comment
Gregi Posted April 18, 2023 Author Share Posted April 18, 2023 Hi @MullinRJ Thank you for your reply. For sure, i did a lot of trying of those two functions 🙂 I put both of them in my script and comment / uncomment. But the vs.vsoGetPluginStyleSym() is always crashing VW. I was wondering, why vs.GetPluginStyleSymbol needs two inputs (in the function reference it says: vs.GetPluginStyleSymbol(hObject, hSymDef)) but it works in this way: bisStyled, StyleSym = vs.GetPluginStyleSymbol(gPio_H, None) #Prüfen, ob PluginObjekt Stilgesteuert ist It is hard to get any information about some functions, especially in combination with event-based PIOs. Probably the "vso"-Function is only meant to work in a special event-case? Gregi Quote Link to comment
MullinRJ Posted April 18, 2023 Share Posted April 18, 2023 Asking for two input parameters may be a mistake, but it may also work as defined if the second parameter is sometimes an input parameter. Some input parameters will accept NIL (or None) as valid input and report differently from passing in a non-NIL value. Again, I'm guessing here as I've never used the function. If it works as you've shown, then use it. Keep notes for future reference. You never know if, or when, things may change. Raymond Quote Link to comment
Pat Stanford Posted April 18, 2023 Share Posted April 18, 2023 I believe VSO functions are for creating "semi-event" objects. If you are creating a true Event Enabled object, I would not use them and would stick to the vanilla VS functions instead. Quote Link to comment
