MikeB
edit saved sheets
When you edit a saved sheet and hit OK you get kicked out of the edit sheet dialogue. It would be better if it sent you back to the list of saved sheets instead so you could edit multiple sheets without having to open the saved sheet dialogue over and over.
What happens to me is that I will have multiple saved sheets and then I will add a layer to the file. Then if I want this layer (or class for that matter) to be vivible in all of my saved sheets I have to open the Saved sheet dialogue over and over for each sheet. With several sheets it can be very time consuming.
Thanks
4 answers to this question
Thank you for your suggestion. We here at Nemetschek North America are always attentive to customer suggestions. Over the years the bulk of all improvements to the MiniCad and VectorWorks programs have come from customer requests.
This will be entered into our wish list and evaluated by our design team as a potential enhancement for the future.
Again, we thank you for your input and continued patronage.
Perhaps even better would be a pull down in the edit sheets dialog that listed all the saved sheets. Then all the editing could be done within that one dialog. Add to this a modifier key so that changes to one sheet would implement the same changes on all sheets. These would be great improvements.
I also notice that you cannot import a saved sheet even though you can see them in the resources palette. It would be great if you could.
"Perhaps even better would be a pull down in the edit sheets dialog that listed all the saved sheets."
Agreed, this would be a great improvement!
