Resizing Sheet Border/Title Block
Hi
Is it possible to resize the Border /Title Block Symbol and remove the double lines around the edge?
So, attached is a file which shows my Title Block/Border. This is A1 size for A1 paper.
However, when I print this, my printer always has to crop it due to Margins. Therefore, in an ideal world I would like to resize this so that the size of the Border/Title Block is slightly under A1 size. When I edit the Title Block Layout, it is not possible to select the Double lines around the edge and resize them.
Is there a way to do this, to effectively make the total size slightly less than A1? I can increase the Title Block Margin sizes all round in the Title Block Settings, which relocates the Inner line further in. Is there a way of getting rid of the outer surround line?
Kind regards
Mike
A1 Border Query.vwx
