Importing 3d model - which format?
AdrianW
Hi,   I've bought a download of a chair that happens to exactly match a real one our client has, and I'd like to feature it in their proposed design model.  I can't seem to import any of the available;e files ( see attached screen shot).  I'm a relative beginner at the 3d modelling and stumble over the nuances such as this.   Can anyone please advise on how I might get this chair into Vectorworks looking like the image?   AND how do I go about dealing with the associated textures?
Thanks
Adrian
Edited by AdrianW
Hi, Thanks.   I just tried that and got the following message ( screen shot).  I unselected the import textures options on import command and tried again...the skeletal form of the model appeared in the drawing for 2 seconds and then disappeared off the drawing ( not zoomed off to a corner either or on class or layer which is off).
place the .obj, .mtl, and related texture in the same folder.
start a new drawing
import the .obj
You should see a fully textured 3d model at that point.
If not, it looks like you bought this off turbosquid.
Contact the seller and see if they will help you, they may not have textured the .obj based on the product description, but that would be unusual.
Edited by jeff prince
start a new drawing
import the .obj
maybe that's where I'm going wrong as the folders are as they downloaded in my downloads folder ( see screen shot).  When importing from import command, it only lets me select a single fie and not a folder full or selection, and so I choose the .obk file.....with no success.   Do I need to move the main obj folder containing the 5 other folder into a vectorwork folder somewhere or into resources?
I did start with importing to a new VW drawing for the failed attempts.
I had obtained advice from Turbosquid ( see screen shot) but their suggestion of unpacking the files with ZIP etc does not seem to be needed as they simply downloaded to my Mac downloads folder in normal accessible file format as you can see in first screen shot.
I have now tried copying all of the files downloaded into a new folder, and importing the .obj file form within that.  I don't get any error messages but it seems to process it in milliseconds ( too fast!) and afterwards there is no imported model, and the drawing is again empty.
Thanks,
Adrian
In my experience, aside from any new magic that 2023 may provide, the only import formats that will maintain textures in VW are .obj or .3ds. oBJ files usually end up larger than .3ds, but they seem to be a bit more reliable. They will probably import in a view you will need to adjust, but that is no big deal.
Also..do make sure you download the texture files and absolutely make sure there is an .mtl file along with the .obj file. Then, in my experience I usually need to have a folder that has both the .obj, the .mtl files and the textures NOT in a separate folder, but just loose in the folder with the .obj and the .mtl files. I download a lot of these from the Turbosquid site, so I know the drill.
As mentioned, if you can’t get all this to work on your end, do upload all the files and I or someone else here can sort it out for you 🙂
5 hours ago, AdrianW said:
maybe that's where I'm going wrong as the folders are as they downloaded in my downloads folder ( see screen shot).  When importing from import…
Yeah, that’s where you are going wrong.
Like I said earlier…
start a new drawing
import the .obj
2 hours ago, VIRTUALENVIRONS said:
Can you post the OBJ zip file and let us have at it.  I don't think that you are doing anything wrong, it seems like the file is the problem, but between all of us trying to help, we may be able to solve the problem.
hi, It wont seem to let me upload any of the files on here! IS there another way of posting the files?
You shouldn’t post files that you purchased, it’s a violation of the use agreement and stealing from the artist.
Follow the procedure and it should work.  If it doesn’t, download an obj viewer or use Apple Preview and see if it is the file.  Blender is a free program that can open obj as well.  If you can open it in another program, the problem is your vectorworks process.  If you can’t open it in another program, contact the vendor.
Okay....all sorted!  I tried again but in a standard VW new file, instead of our company preset new template drawing.  It's pasted into the main drawing happily too.  So, thank you for all of your help, and sorry to waste your time, but I've learned from this exchange too anyway.
Adrian
  • Like 4
I repeatedly have  this problem as well with purchased model assets, and the solutions are not consistent.  Yes, putting the textures in the same folder as the obj and mtl makes it more likely to work, but it is not a guarantee.
I have on a few occasions used Blender as an intermediary-- importing the obj to blender then exporting it  back to obj and i have had some success with that when a direct import fails.  Even so, the textures can become detached from the obj, or one of several effects will be transferred, but not all.  Currently I am getting what appears to be the bump channel of a purchased model but not the color.  When i try to manually drop the texture for the color back into the model, the mapping is not imported, so the texture just tiles instead.  Any ideas that someone has would be greatly appreciated.
Vectorworks will usually warn you if it can't find a texture during the import.  I believe the standard behavior is for Vectorworks to read the .mtl file to find out how to locate and map the texture resources.  If you have the textures in the same folder as the model, it will resolve them... Unless, the person who prepared the .obj file did a sloppy job of formatting the .mtl, either due to their software or laziness.  I have seen some purchased models have a different texture file name than what is spelled out in the .mtl file.  Typically, fixing that either by renaming the file or changing the name in the .mtl will solve the majority of issues.
