Popular Post bjoerka Posted March 21, 2023 Popular Post Share Posted March 21, 2023 Please add the ability to group layers in the layer tab! Please let layers be linked to others with drag & drop. Please do not implement a grouping like it is done with classes to sort them by a prefix. This would be to complicated to have a flexible layer structure. 31 Quote Link to comment
0 line-weight Posted November 12, 2024 Share Posted November 12, 2024 27 minutes ago, Tom W. said: I don't really have a suitable file to send you but I think this post sets out fairly comprehensively the returns (in my case at least) you get on using Materials: I think I'm going to implement a similar approach as you describe & start using materials in my next project. As of VW2025, do we have any object types that still can't accept materials? Looking into this a couple of years back, it seemed there were a few things where this was the case. Quote Link to comment
0 Tom Klaber Posted November 12, 2024 Share Posted November 12, 2024 34 minutes ago, line-weight said: You can sort-of do this using "saved sets" within the "Publish" command. Unfortunately it's very difficult to get a clear overview of what's actually in all of your saved sets because all you have is this tiny dialogue... and if you want to see what's in one of those sets you have to recall it. Even just having an improved "Saved Sets" interface would go a long way to providing what's described above. And then, being able to access those "saved sets" as part of the sheet layers navigation dialogue. That would make it quite a bit easier to keep on top of things when there are large numbers of sheet layers. Yes. Saved sets are OK - I wish it would not ask me EVERYTIME I exported anything if I wanted to save it as a set - but it does not solve the fundamental issue of long term project organization - its like a little time saver at the very last step - a seat warmer in a jalopy. 2 Quote Link to comment
0 Tom W. Posted November 12, 2024 Share Posted November 12, 2024 38 minutes ago, line-weight said: do we have any object types that still can't accept materials? Yes probably. But for me it's really only in Components that I use them so doesn't affect me one way or the other. Quote Link to comment
0 E|FA Posted November 12, 2024 Share Posted November 12, 2024 2 hours ago, line-weight said: do we have any object types that still can't accept materials? Looking into this a couple of years back, it seemed there were a few things where this was the case. This was what stopped me from trying to use Materials when first introduced - in particular they couldn't be used on doors & windows. I believe that Materials are now universal, but someone may need to correct me. I am planning on switching to Materials when I switch to VW2025. Quote Link to comment
0 Tom W. Posted November 12, 2024 Share Posted November 12, 2024 1 hour ago, E|FA said: I believe that Materials are now universal, but someone may need to correct me. I had a quick look + the only objects I could find that don't accept Materials were WinDoor, Massing Model, Floor, Pillar, Roadway, Ramp + Chain Extrude... 2 Quote Link to comment
0 Matt Overton Posted November 21, 2024 Share Posted November 21, 2024 On 8/18/2024 at 6:09 PM, Tom W. said: OK got it: Materials allow you to turn a model that looks like it is made from certain products/materials into one which is made from those products/materials. Did I miss some massive upgrade to how materials work because they don’t actually create a model that looks right unless the material is uniform. Quote Link to comment
0 Tom W. Posted November 21, 2024 Share Posted November 21, 2024 6 hours ago, Matt Overton said: Did I miss some massive upgrade to how materials work because they don’t actually create a model that looks right unless the material is uniform. What do you mean 'material is uniform'...? The model will look the same whether the attributes/textures are applied by object, by class or by Material. Quote Link to comment
0 Matt Overton Posted November 24, 2024 Share Posted November 24, 2024 On 11/21/2024 at 5:20 PM, Tom W. said: What do you mean 'material is uniform'...? The model will look the same whether the attributes/textures are applied by object, by class or by Material. Take timber, which has a direction that works effectively in structures and different appearances along the structural line verse across the structure. Your brain understands this even if you don't and flags it as an oddity or worse as a sign the structure is unsafe. If you want a render to be well received you either have to get that right or make it more sketchy. Materials offer no benefits to classes because they don't expand on the classes' ability. To bring it back to topic. What would have really helped reduce class complexity is layer grouping and viewport styles that understood layers that repeat within different groups, because materials didn't. Quote Link to comment
0 Tom W. Posted November 24, 2024 Share Posted November 24, 2024 1 hour ago, Matt Overton said: Take timber, which has a direction that works effectively in structures and different appearances along the structural line verse across the structure. Your brain understands this even if you don't and flags it as an oddity or worse as a sign the structure is unsafe. If you want a render to be well received you either have to get that right or make it more sketchy. Materials offer no benefits to classes because they don't expand on the classes' ability. Correct. Materials do not have built-in UV mapping or the ability to change how textures are handled by PIOs like Doors/Windows. They are just a different way of applying textures + whether they offer benefits in that respect over classes is subjective. The advantage is that you can have one Material per material/product in the model rather than multiple classes + because you are controlling textures/attributes independently of classes that frees up classes to be used solely for visibility or organisational purposes. But Materials are only 50% about appearance. The rest is about data. Quote Link to comment
0 Matt Overton Posted November 24, 2024 Share Posted November 24, 2024 14 hours ago, Tom W. said: Correct. Materials do not have built-in UV mapping or the ability to change how textures are handled by PIOs like Doors/Windows. They are just a different way of applying textures + whether they offer benefits in that respect over classes is subjective. The advantage is that you can have one Material per material/product in the model rather than multiple classes + because you are controlling textures/attributes independently of classes that frees up classes to be used solely for visibility or organisational purposes. But Materials are only 50% about appearance. The rest is about data. I still content better layers and layers groups would do more to allow effective management of complexity and would have allowed materials to do the job well. Quote Link to comment
0 Tom W. Posted November 25, 2024 Share Posted November 25, 2024 10 hours ago, Matt Overton said: I still content better layers and layers groups would do more to allow effective management of complexity and would have allowed materials to do the job well. I don't see that Materials are relevant to the OP at all to be honest. 3 Quote Link to comment
0 Tom Klaber Posted September 10, 2025 Share Posted September 10, 2025 We need Layer Organization. Thought this would be the year.... 2 Quote Link to comment
0 Matt Overton Posted September 10, 2025 Share Posted September 10, 2025 7 hours ago, Tom Klaber said: We need Layer Organization. Thought this would be the year.... It doesn’t even have a card on the roadmap along with the other half dozen top voted Wishlist items that also don’t have a place in the roadmap.. then again the roadmap might be way out of date given “worksheets pagination” is active research and a tentpole of the current release. 1 Quote Link to comment
0 rDesign Posted September 11, 2025 Share Posted September 11, 2025 52 minutes ago, Matt Overton said: It doesn’t even have a card on the roadmap along with the other half dozen top voted Wishlist items that also don’t have a place in the roadmap.. then again the roadmap might be way out of date given “worksheets pagination” is active research and a tentpole of the current release. It is on the Roadmap, under ‘Active Research’: https://www.vectorworks.net/en-US/public-roadmap?url=layer-grouping 3 Quote Link to comment
0 Matt Overton Posted September 11, 2025 Share Posted September 11, 2025 6 hours ago, rDesign said: It is on the Roadmap, under ‘Active Research’: https://www.vectorworks.net/en-US/public-roadmap?url=layer-grouping Oops… I missed as is sits right next to another card I was lamenting the lack of progress on. 1 Quote Link to comment
0 Tom Klaber Posted September 11, 2025 Share Posted September 11, 2025 I am not sure how upto date that is as the spreadsheet enhancements included in this year's release are hinted at in a research card. 4 hours ago, Matt Overton said: Oops… I missed as is sits right next to another card I was lamenting the lack of progress on. Quote Link to comment
0 bjoerka Posted January 22 Author Share Posted January 22 On 9/11/2025 at 2:34 AM, rDesign said: It is on the Roadmap, under ‘Active Research’: https://www.vectorworks.net/en-US/public-roadmap?url=layer-grouping yes. and it is still there and not elsewhere... 2 Quote Link to comment
bjoerka
Top Posters For This Question
12
9
7
5
Popular Days
Sep 18
9
Nov 12
9
Aug 15
5
Mar 21
4
Tom W. 12 posts
bjoerka 9 posts
Tom Klaber 7 posts
Matt Overton 5 posts
Popular Days
Sep 18 2024
Nov 12 2024
Aug 15 2024
Mar 21 2023
Popular Posts
bjoerka
Christiaan
Quite a popular wish, including one from me back in 2007: https://forum.vectorworks.net/index.php?/topic/102316-nested-layers-wanted/ https://forum.vectorworks.net/index.php?/topic/96
bjoerka
this is a so essential wish... it can´t be wished as often as possible. maybe someone can write a marionette to wish this once a week automatically 🙂
Posted Images
67 answers to this question
