Ramon PG Posted March 21 Share Posted March 21 (edited) Edited March 21 by Ramon PG added another view Quote Link to comment
0 Ramon PG Posted March 29 Author Share Posted March 29 On 3/20/2023 at 9:37 PM, Ramon PG said: @Pat Stanford Any pointers? I've tried a couple of hatches and I get the same slanted effect. Thanks. Quote Link to comment
0 Pat Stanford Posted March 29 Share Posted March 29 I don't understand the problem. I can see that you have square tiles and you have angled tiles, but I don't know which one is correct and what you are trying to do. Which is the hatch and which is the texture? 1 Quote Link to comment
0 Ramon PG Posted March 29 Author Share Posted March 29 2 hours ago, Pat Stanford said: I don't understand the problem. I can see that you have square tiles and you have angled tiles, but I don't know which one is correct and what you are trying to do. Which is the hatch and which is the texture? Soory for the confusion. The left drawing is shaded with hidden line and the right one is just hidden line. The hatch on both sows OK when opened in the Resource Manager, yet it show slanted in elevation and replacing it with another 4x4 hatch gives the same results. Seems random, but prob is not. I just can't figure the method to the madness. Quote Link to comment
0 Tom W. Posted March 30 Share Posted March 30 Maybe you should post the file @Ramon PG. Does the surface Hatch display correctly when the render mode is Hidden Line on the design layer? What about when applied to a planar object? What about non section VPs? Are there any section VPs where it displays correctly? Quote Link to comment
0 Ramon PG Posted March 30 Author Share Posted March 30 12 hours ago, Tom W. said: Maybe you should post the file @Ramon PG. Does the surface Hatch display correctly when the render mode is Hidden Line on the design layer? What about when applied to a planar object? What about non section VPs? Are there any section VPs where it displays correctly? Same wall... Shaded: Hidden Line: Same walls (6 and 7) in SVPs: Planar Object (dame hatch): Quote Link to comment
Ramon PG
added another view
5 answers to this question
