I'd like to see a tutorial showing how to adjust various elements to each other which reside on different layers. A good example would be roofs to walls. With Align Layer Views and Cut 3D Section having been moved out of the active tool set (in Architect, anyway) the job of adjusting elements against each other just got way harder. One cannot measure between elements of a model shown in a Viewport or between elements of a model using the Stacked Layers--there is no measurable scale tied to these "view-only" images. Also, one cannot cut a Viewport Section and convert it to lines in its original scale, or any scale that I can figure out. So I'd love to read how to make measurements work. Thanks.
TomG
1 answer to this question
