BJRobinson Posted March 19, 2023 Share Posted March 19, 2023 Hi. Is there a way of copying the plant list from one landscape area to another? Thanks. Quote Link to comment
Tom W. Posted March 19, 2023 Share Posted March 19, 2023 Only by replacing the style in the OIP I think... 1 Quote Link to comment
Amanda McDermott Posted March 20, 2023 Share Posted March 20, 2023 I've a feeling you can use the eyedropper tool, if you get the settings right... @Nic_Berry might know? Quote Link to comment
Peter W Flint Posted March 31, 2023 Share Posted March 31, 2023 Yes. Create your LA geometry as closed polygons then select LA tool, eyedropper mode will pick up the settings from your original landscape area, then switch to fill mode and apply to your new polygons. PWF Quote Link to comment
Tom W. Posted March 31, 2023 Share Posted March 31, 2023 2 minutes ago, Peter W Flint said: Yes. Create your LA geometry as closed polygons then select LA tool, eyedropper mode will pick up the settings from your original landscape area, then switch to fill mode and apply to your new polygons. PWF This is true but is not what @BJRobinson was asking... Quote Link to comment
Michal Zarzecki Posted April 17, 2023 Share Posted April 17, 2023 On 3/31/2023 at 3:06 PM, Peter W Flint said: Yes. Create your LA geometry as closed polygons then select LA tool, eyedropper mode will pick up the settings from your original landscape area, then switch to fill mode and apply to your new polygons. PWF This was true before 2022. I asked the same question a few months ago and now one has to tick that the plant list is by style to be able to copy it using the Eyedropper Mode. Otherwise, a Landscape Area with an empty list will be created. I preferred how it worked before. See our previous discussion here: 2 Quote Link to comment
