Gonda Posted Saturday at 08:18 PM Share Posted Saturday at 08:18 PM (edited) Hey All, So, installed the Dialog Builder through the Partner Products section... Once I restarted VW, I did see the DB Floating Tool Palette but it only has 4 items: A. Test Run B. Tools C. Renumberer D. Static Text I've poked around the workspace editor to see if I was missing something (menu, adding tools to the palette, etc), but for the life of me I can't find the tools to actually layout things in DB (buttons, text boxes, popup's, etc)... Am I just missing something incredibly obvious? Is DB broken? Running VW2023 SP4 on MacOS Ventura on Apple Silicon. Cheers, -g Edited Saturday at 08:18 PM by Gonda Quote Link to comment
JBenghiat Posted Saturday at 09:59 PM Share Posted Saturday at 09:59 PM The layout items are all plug-in objects; insert a static text item and then change it's type to the desired item. Note, you are building more of a connected tree than a visual layout, a lot like marionette, so what you see in the VW document looks nothing like the resulting dialog. 1 Quote Link to comment
Pat Stanford Posted Sunday at 02:24 AM Share Posted Sunday at 02:24 AM The documentation is far out of date. Do as @JBenghiat suggests and you can accomplish everything you need to with the DB. Quote Link to comment
Sam Jones Posted Sunday at 04:51 PM Share Posted Sunday at 04:51 PM As Josh said place a static text item and then change the item type. Do this with the pop up menu in the OIP. 18 hours ago, JBenghiat said: The layout items are all plug-in objects; insert a static text item and then change it's type to the desired item. Quote Link to comment
