setdesigner Posted March 17 Share Posted March 17 I am trying to incorporate Cloud Services in my workflow. I have a few questions: When generating a pdf from the cloud, Redshift viewports are not rendering. Any time frame when this will be available ? I don't want to generate all sheets in my file, some are left for template use, any way to select sheets to be generated in the pdf ? I have reference files, they are not included when generating 3d wgx, is this normal ? Thanks Quote Link to comment
0 Vectorworks, Inc Employee inikolova Posted March 20 Vectorworks, Inc Employee Share Posted March 20 @setdesigner, Redshift rendering is available on the cloud, please send me a personal message with your username, so I can investigate why it may not be working in your case. You can use the Publish command in Vectorworks to select individual sheets for export and submit to the cloud for processing. Yes, referenced geometry is not supported in the .vgx export currently. 1 Quote Link to comment
0 Vectorworks, Inc Employee inikolova Posted March 23 Vectorworks, Inc Employee Share Posted March 23 Just to follow up here for anyone reading this post... After further investigation, it was determined that referenced geometry is getting exported in the .vgx file and appears to be working fine. Quote Link to comment
setdesigner
Thanks
2 answers to this question
