DomC Posted March 17, 2023 Share Posted March 17, 2023 Hi Does anybody know, how to get a handle related to the geometry of the vp cache "vs.GetVPGroup(h, 3) or the VP coordinates to the Object on the Design Layer? Target would be tagging or annotate Elements in a Section viewport by script. Somehow it would work because the data-tag can also can access to this elements. I can imagine that it is necessary to evaluate the original object of a location from the vp coordinates and the section plane. Or is there an other solution for that? DomC Quote Link to comment
Pat Stanford Posted March 17, 2023 Share Posted March 17, 2023 I have not done anything with the cache, but assuming it is like Annotations, then FInGroup(GetVPGroup(H,3)); should get you the first object in the cache. Then just use NextObject to iterate until you find what you are looking for or until you get a Nil return. HTH and keep us posted on what works. Quote Link to comment
JBenghiat Posted March 20, 2023 Share Posted March 20, 2023 The VP cache just literally contains the lines and polylines that make up the hidden line render. If you're annotating by the physical appearance in the VP (e.g. object heights), this could work, but you won't be able to access the drawing objects. Data tags use some special code that's not available in VS or the SDK. My guess it that the attachment tool is using the VP view and visibility settings to query objects in the corresponding design layers. Quote Link to comment
DomC Posted March 28, 2023 Author Share Posted March 28, 2023 Thanks for your worthwhile feedbacks. So far my strategy (But I do not know if it will work reliable enough) 1. Inside the Section there is a Section Line Type 86 that contains the position of the section and a direction matrix 2. There are Informations on the Section VP directly that tells, if section is horizontal or vertical 3. The VP cache Group contains the projected geometry of the elements In combination of this 3 information it is possible to compare the Design-Layer coords and the section coords. I build some functions to test what works. So far i see the following stumbling stocks: - There are differences if the horizontal section was created from clip cube or from sectioning a VP - VP cache has not the same informations if the objects behind section plane are disabled - So far my function are not secure to return always the right informations Prototype Method to get Section Line: Gets Section Informations = vs.FSActLayer() rname = 'Section Line2' def create_field_value_dict(obj, rname): rhandle = vs.GetObject(rname) num_fields = vs.NumFields(vs.GetObject(rname)) fdict = {'found' : True} for i in range(1, num_fields+1): fname = vs.GetFldName(rhandle, i) value = vs.GetRField(obj, rname, fname) fdict[fname] = value return fdict def get_sl_in_vp(vp): obj = vs.GetVPGroup(vp, 2) #vs.Message(str(obj)) groups = [] while obj != vs.Handle(0): t = vs.GetTypeN(obj) if t == 11: groups.append(obj) obj = vs.NextObj(obj) section_line = vs.Handle(0) #vs.Message(str(groups)) for group in groups: obj = vs.FInGroup(group) while obj != vs.Handle(0): t = vs.GetTypeN(obj) n = rname if t == 86 and n == 'Section Line2': section_line = obj break obj = vs.NextObj(obj) return section_line section_line = get_sl_in_vp(h) m = vs.GetEntityMatrix(section_line) fdict = create_field_value_dict(section_line, rname) fdict['entity_matrix'] = m fdict['is_horizontal'] = vs.GetObjectVariableBoolean(h, 1048) vs.Message(str(fdict)) Prototype Method to get VP cache infos: This Function puts a 3D Locus on the Design-Layer in Projection to the Objects vertical to Section Plane. h = vs.FSActLayer() rname = 'Section Line2' lh = vs.GetLayerByName('Konstruktionsebene-1') fdict = {} def create_field_value_dict(obj, rname): rhandle = vs.GetObject(rname) num_fields = vs.NumFields(vs.GetObject(rname)) fdict = {'found' : True} for i in range(1, num_fields+1): fname = vs.GetFldName(rhandle, i) value = vs.GetRField(obj, rname, fname) fdict[fname] = value return fdict def get_poly_in_vp(vp): obj = vs.GetVPGroup(vp, 3) groups = [] while obj != vs.Handle(0): t = vs.GetTypeN(obj) if t == 11: groups.append(obj) obj = vs.NextObj(obj) #vs.AlrtDialog(str(groups)) objs = [] for group in groups: obj = vs.FInGroup(group) while obj != vs.Handle(0): t = vs.GetTypeN(obj) #vs.AlrtDialog(str(t)) if t in [5, 21]: if vs.GetFPat(obj) != 0: objs.append(obj) obj = vs.NextObj(obj) return objs objs = get_poly_in_vp(h) fdict['polys'] = objs fdict['is_horizontal'] = vs.GetObjectVariableBoolean(h, 1048) vs.AlrtDialog(str(fdict['is_horizontal'])) #vs.AlrtDialog(str(objs)) def get_center_points(objs): center_points_3D = [] for obj in objs: p = vs.HCenter(obj) if fdict['is_horizontal']: m_pt = p[0], p[1], 0 vs.AlrtDialog(str(m_pt)) else: #vertical section y = z m_pt = p[0], 0, p[1] center_points_3D.append(m_pt) return center_points_3D center_points_3D = get_center_points(objs) for p in center_points_3D: vs.Locus3D(p) locus = vs.LNewObj() #vs.SetParent(obj, lh) vs.SetParent(locus, lh) And next prototype Method can check if the center point of the section cache-geometry is inside the parent object on the design-layer. lh = vs.ActLayer() ln = vs.GetLName(lh) espsilon = 1 c = "(INOBJECT & NOTINDLVP & NOTINREFDLVP & ((L='l-dummy') & (PON='XG Custom Part')))" c = c.replace('l-dummy', ln) custom_parts = [] def add_handle(h): custom_parts.append(h) vs.ForEachObject(add_handle, c) def is_pt3_in_cube(pt, cube, epsilon): x, y, z = pt xmin2, xmax2, ymin2, ymax2, zmin2, zmax2 = cube # vs.Message(str(cube)) overlapx = overlapy = overlapz = False if xmin2 - epsilon < x < xmax2 + epsilon: overlapx = True if ymin2 - epsilon < y < ymax2 + epsilon: overlapy = True if zmin2 - epsilon < z < zmax2 + epsilon: overlapz = True return min(overlapx, overlapy, overlapz) def bbox3D(p, zValue, height, width, depth): centerPt = (p[0], p[1], zValue) botZ = zValue - depth / 2 topZ = zValue + depth / 2 w2 = width / 2 h2 = height / 2 bbox_bl = p[0] - w2, p[1] - h2 bbox_tr = p[0] + w2, p[1] + h2 bbox_tl = p[0] - w2, p[1] + h2 bbox_br = p[0] + w2, p[1] - h2 xmin = bbox_tl[0] xmax = bbox_br[0] ymin = bbox_br[1] ymax = bbox_tl[1] zmin = botZ zmax = topZ return [xmin, xmax, ymin, ymax, zmin, zmax], ((xmin, ymin, zmin), (xmin, ymax, zmin), (xmax, ymax, zmin), (xmax, ymin, zmin), (xmin, ymin, zmax), (xmin, ymax, zmax), (xmax, ymax, zmax), (xmax, ymin, zmax)) #h = vs.FSActLayer() h = custom_parts[0] parent = vs.GetParent(vs.GetParent(h)) BOOLEAN, offset, rotationXAngle, rotationYAngle, rotationZAngle = vs.GetEntityMatrix(parent) (p, zValue) = vs.Get3DCntr(h) (height, width, depth) = vs.Get3DInfo(h) cube, pts = bbox3D(p, zValue, height, width, depth) is_in_cube = is_pt3_in_cube(pt, cube) for pt in pts: x, y, z = pt x = x + offset[0] y = y + offset[1] z = z + offset[2] pt = x,y,z vs.Locus3D(pt) Additional it would help to check classes and attributes to be sure not targeting an invisible object etc. With this 3d Methods it is possible to manually make a relation between a coord point inside the section annotations and the object on the design-layer. The shakiness of this strategy here is, that the Method of traversing the VP to collect Section-Line and Section Geometry is maybe not reliable enough or can wreck after an VW Update. Further it can be tricky to get positions of rotated and nested object rotations. That would be the the hardest part. Even the Data-Tag hat some (fixed) issues to find the Objects in every situation so I do expect that would be really expensive to solve that. Also I saw, that I corrupted some VP after working on them with this scripts. But I think this was because of creating Test-Marker-Objects inside the VP. At the end, this would be a "read-only" access to the VP which should not corrupt anything -SHOULD. I will pause working on that specific feature ☺️ Quote Link to comment
Marco Zavagno Posted March 28, 2023 Share Posted March 28, 2023 Ouch... literally no clue what all this is about... I feel like a monkey in a space rocket.. 2 Quote Link to comment
JBenghiat Posted March 28, 2023 Share Posted March 28, 2023 I think you'll have better luck using the object variables rather than looking at the cache group: // Viewport type selectors // -------------- const short ovViewportProjectionType = 1000; // short read/write - the viewport projection type. - Public for VS const short ovViewportRenderType = 1001; // short read/write - the viewport render type. - Public for VS const short ovViewportPerspectiveDistance = 1002; // real read/write - the viewport perspective distance (used with custom perspective). - Public for VS const short ovViewportScale = 1003; // real read/write - the viewport scale. - Public for VS const short ovViewportDirty = 1004; // Boolean read/write - the viewport out-of-date (dirty) state. - Public for VS const short ovViewportProject2D = 1005; // Boolean read/write - the viewport project 2D state. - Public for VS const short ovViewportRenderBackground = 1006; // Sint32 read/write - the viewport render background. - Public for VS const short ovViewportViewType = 1007; // short read/write - the viewport view type. - Public for VS const short ovViewportLineWeightScale = 1008; // double read/write - the viewport line weight scale. - Public for VS const short ovViewportArrowheadScale = 1009; // double read/write - the viewport arrowhead scale. - Public for VS const short ovViewportDashedLineScale = 1010; // double read/write - the viewport dashed line length/spacing scale. - Public for VS const short ovViewportHatchLineScale = 1011; // double read/write - the viewport hatch line spacing scale. - Public for VS const short ovViewportDesignTextScale = 1012; // double read/write - the viewport design layer referenced text size scale. - Public for VS const short ovViewportSlashThicknessScale = 1013; // double read/write - the viewport slash thcikness scale. - Public for VS const short ovViewportAmbientIsOn = 1014; // Boolean read/write - the viewport ambient light is ON or OFF. - Public for VS const short ovViewportAmbientBrightness = 1015; // double read/write - the viewport ambient light brightness. - Public for VS const short ovViewportAmbientColor = 1016; // WorldPt3 read/write - the viewport ambient light color. - Public for VS const short ovSetDesignLayerVisibilityInAllViewports = 1017; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovSetClassVisibilityInAllViewports = 1018; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovViewportHDRIBackground = 1019; // Sint32 read only - the background for environment lighting - Public for VS const short ovSectionVP2DAttributeClass = 1020; // Sint32 read only - the RefNumber of the class responsible for attributes of overall cross-section or just the x-section of structural elements. - Public for VS const short ovSectionVP2DOtherAttribClass = 1021; // Sint32 read only - the RefNumber of the class responsible for attributes of cross-section generated from non-structural elements - Public for VS const short ovSectionVP3DFillStyleClass = 1022; // Sint32 read only - the RefNumber of the class reposnsible for fill style of the objects beyond section plane - Public for VS const short ovSectionVP3DLineStyleClass = 1023; // Sint32 read only - the RefNumber of the class responsible for line style of the objects beyond section plane - Public for VS const short ovViewportXPosition = 1024; // double read only - the X coordinate of the viewport on the sheet layer - Public for VS const short ovViewportYPosition = 1025; // double read only - the Y coordinate of the viewport on the sheet layer - Public for VS const short ovViewportAngleWithXAxis = 1026; // double read only - the angle that the viewport subtends with the X axis on the sheet layer in degrees - Public for VS const short ovViewportShowWallComponents_OBSOLETE = 1027; const short ovViewportGrayTransparent = 1028; // Boolean read/write - the viewport renders gray layers transparent - Public for VS const short ovViewportFlipText = 1029; // Boolean read/write - the viewport/dlvp adjusts for flipped text - Public for VS const short ovViewportBlackAndWhite = 1030; // Boolean read/write - the viewport/dlvp draws in black and white only - Public for VS const short ovViewportUseDocumentClassVis = 1031; // Boolean read/write - set/reads the Use Document Class visibilities settings for dlvps - Public for VS const short ovViewportDescription = 1032; // TXString read/write - a description for the viewport, which corresponds to the Dwg Title field for a corresponding Drawing Label. - Public for VS const short ovViewportLocator = 1033; // TXString read/write - the locator for the viewport, which corresponds to the Item field for a corresponding Drawing Label. - Public for VS const short ovViewportIsLinked = 1034; // Boolean read - indicates whether the viewport is a linked viewport const short ovViewportDisplayPlanar = 1035; // Boolean read/write - the flag to indicate if planar and 2D objects are to be displayed const short ovViewportForegroundRenderType = 1036; // short read/write - the viewport render type. - Public for VS const short ovViewportHasCamera = 1037; // Boolean read only - whether there is a camera attached to the viewport or not const short ovCameraAttachedToViewport = 1038; // Boolean read only - whether the camera is attached to a viewport or not const short ovViewportCropVisible = 1039; // Boolean read/write - get/set the Crop Visible state of a viewport - Public for VS const short ovViewportLayerHeightIgnored = 1040; // Boolean read only - whether the viewport ignored layer height for single layer case const short ovViewportLightingDevice = 1041; // read/write - make an association between a lighting device light and an overriden light object for the viewport. const short ovViewportRePositionDimensionText = 1042; // Boolean read/write - the viewport/dlvp re-positions dimension text to other side of dimension line - Public for VS const short ovIsDesignLayerSectionViewport = 1043; // Boolean read only - indicates whether the linked viewport is a sheet layer or a design layer viewport - Public fo VS const short ovFDLSVPHiddenLineInWireframe_OBSOLETE = 1044; const short ovViewportPageSymbolScale = 1045; // double read/write - the viewport page symbol scale. - Public for VS const short ovViewportNavigateToFromSectMarker = 1046; // Boolean write only - selects the viewport and makes it visible - Not for public use const short ovViewportDetailLevel = 1047; // short read/write - low detail = 0, medium detail = 1, high detail = 2 - Public for VS const short ovViewportIsHorizontalSection = 1048; // Boolean read - indicates whether the viewport is horizontal section const short ovViewportTransformMatrix = 1049; // TransformMatrix read/write const short ovViewportViewMatrix = 1050; // TransformMatrix read/write const short ovViewportOperatingTransform = 1051; // TransformMatrix read const short ovViewportUnscaledBoundsWithoutAnnotations = 1052; // WorldRect read const short ovViewportResetForOnlyAnnotationsChange = 1053; // void write const short ovIsSectionViewport = 1054; // Boolean read only - indicates whether the viewport is a section viewport - Public for VS const short ovSheetLayerSectionViewportViewMatrix = 1055; // TransformMatrix read const short ovSectionViewportSectionViewMatrix = 1056; // TransformMatrix read/write const short ovViewportAttachDefaultRenderOptions = 1057; // Boolean(ignored) write const short ovViewportAttachDefaultCustomRenderWorksRenderOptions = 1058; // Boolean(ignored) write const short ovViewportDisplay2DComponents = 1059; // Boolean read/write const short ovViewportHiddenLineDisplay2DFills = 1060; // Boolean read/write const short ovViewportAttachDefaultLightingOptions = 1061; // void write const short ovViewportCreateDefaultEditableGroups = 1062; // void write const short ovViewportPrivateLayer = 1063; // MCObjectHandle read const short ovSectionViewportDisplayObjectsBeyondCutPlane = 1064; // Boolean read/write const short ovSectionViewportDisplayObjectsBeforeCutPlane = 1065; // Boolean read/write const short ovViewportHiddenLineDisplay2DFillsAllowed = 1066; // Boolean read const short ovSectionViewportCastShadowsFromRemovedPortion = 1077; // Boolean read/write const short ovSectionViewport2DResultsMerged = 1078; // Boolean read/write const short ovSectionViewport2DAttributesUseClass = 1079; // Boolean read/write - must be set true before you set class with ovSectionViewport2DAttributesClass const short ovSectionViewport2DAttributesClass = 1080; // RefNumber read/write const short ovSectionViewport2DOtherAttribsUseClass = 1081; // Boolean read/write - must be set true before you set class with ovSectionViewport2DOtherAttribsClass const short ovSectionViewport2DOtherAttribsClass = 1082; // RefNumber read/write 2 Quote Link to comment
Sam Jones Posted March 28, 2023 Share Posted March 28, 2023 @JBenghiat Please confirm: Get/SetObjectVariableBoolean() will handles "Boolean" values Get/SetObjectVariableInt() will set "handles "short"values Get/SetObjectVariableLongInt() will handles "double" values Get/SetObjectVariableReal() will handles "real" values Get/SetObjectVariableString() will handles "TXString" values What handles (gets/sets): "Sint32" "TransformMatrix" "void" write "RefNumber" Are the constants labeled "Public for VS" the only ones accessible to vectorscript? Yet again, TIA. Quote Link to comment
JBenghiat Posted March 28, 2023 Share Posted March 28, 2023 (edited) Double and real are synonymous. They both map to reals. Sint32 is a signed 32 bit integer. It maps to LONGINT. void is nothing, so there is no return. Using the standard SetOV call will probably work, ignoring the second argument. RefNumber is another LONGINT. It should work with Index2Name. I’m not sure what TransformationMatrix would return, if it works. In C, it’s an object that holds the transformation matrix as arrays. Calls marked “public for vs” just means that they duplicate a function elsewhere, but the only way you can access through VS is via an object variable. I think any call will work, it just may or may not return usable data. Edited March 29, 2023 by JBenghiat 1 Quote Link to comment
MullinRJ Posted March 28, 2023 Share Posted March 28, 2023 Hi Sam, You have the 1st five correct. Short is an integer, so use Get/SetObjectVariableInt. Sint32 is a Longint, so use Get/SetObjectVariableLongInt. The "RefNumber" shown above are type Sint32 (Longint) - see previous line. I'm guess on the "void write" entries, but judging from their ovNames, they may be BOOLEAN, but you can only write to then, and not read them. Not sure how to read or write a transform matrix from VS. 1 Quote Link to comment
DomC Posted April 3, 2023 Author Share Posted April 3, 2023 The Marionette Result of scanning the OV of a Viewport from 0 - 5000. I think it would need a function like calling an array but the only array what is callable for object-variables is a point tuple. Quote Link to comment
