Elite Exhibits Posted Wednesday at 08:31 PM Share Posted Wednesday at 08:31 PM Script to automate Worksheet options when counting Symbols ie: More Choices It is simple to make a Worksheet that counts all the symbols in a drawing - When there is a need to remove some specific symbols from the Worksheet, it is easy to select the More Choices in the Criteria, and select is not. (See attached - Green Arrow) Selecting the Symbols from the VW provided - non searchable - list is often the complexity. I have attempted to type the resulting string directly into the Worksheet Criteria. (See attached - Red Arrow) One needs to have a remarkable memory to enter the Exact Symbol names. (Example Symbol Names also attached) So ... . The request would be to have a script that lets one select Symbol... is not... and then select several symbols vs the addition via More Choices, , then More Choices, then More choices ... Etcetera Suggestions are welcome Peter Symbol Count Criteria_1.pdf Symbol Names_1.pdf Quote Link to comment
MullinRJ Posted 1 hour ago Share Posted 1 hour ago Hi Peter (@Elite Exhibits), Do you need to see the symbol thumbnails, or just the symbol names, in a list when you are making your choices? Your request is doable, but not necessarily easy. Viewing the thumbnails would be more difficult than just viewing the names. Raymond Quote Link to comment
