demetris ktorides Posted Wednesday at 05:58 PM Share Posted Wednesday at 05:58 PM Hello, I am wondering if there's a way to quickly navigate from the sheet layers to the design layers and vice versa. I find myself going back and forth resolving issues and it feels slow to have to click to the 'layer' icon on the navigation tab and click to select the desired layer. Is there a shortcut that takes me 'back' to the design layer I was, or the last sheet layer - without having to search for the icons and select the design layers each time? Thanks, Demetris Quote Link to comment
markdd Posted Wednesday at 06:10 PM Share Posted Wednesday at 06:10 PM (edited) Have you thought about using the Multiple Views function. I do this all the time when troubleshooting class visibilities in Viewports. You can reduce the multiple views to just two and have the Sheet Layer on one, and the design layers on the other. Edited Thursday at 04:18 PM by markdd 1 Quote Link to comment
Pat Stanford Posted Wednesday at 11:17 PM Share Posted Wednesday at 11:17 PM Right click on the Viewport and choose Edit Design Layers? This will zoom you to the Design layer and the crop. There is an option to put is bold green rectangle (that you need to remove manually) to show you where the crop object sits in the viewport. 1 Quote Link to comment
Elite Exhibits Posted Thursday at 04:15 PM Share Posted Thursday at 04:15 PM FYI I use Saved Views and jump back and forth to the specifics set when I make the Saved View I have used this to go from inside (Edit Annotations) in a viewport, directly inside another viewport - when I want to copy and paste specifics for uniformity. I often use nebulous names like 111 & 222 then I am able to over write them as the needs arise Peter 2 Quote Link to comment
Mat Caird Posted Friday at 01:58 AM Share Posted Friday at 01:58 AM On the layers dropdown, chose "recently used layers" Then use CMD up arrow or CMD down arrow You may have to draw a line on the layer you want to show as recently used. 1 Quote Link to comment
demetris ktorides Posted Saturday at 05:12 PM Author Share Posted Saturday at 05:12 PM thank you for your responses all, I am quite new at VW and I've learned a lot from your comments. @markdd,had no idea that you could have multiple views some with design layers and some with sheet layers! This works great for me - and especially the 'create floating frame' is excellent for people using more than one screen monitors. @Pat Stanford, the 'edit layer' command, is great - sometimes laggy on my pc and I am trying to avoid it. Also didn't ever catch that you can filter the layers on the list, thanks @Mat Caird @Elite Exhibits the saved views one caught me be surprise. It's brilliant, I love how flexible VW can be. best, D Quote Link to comment
