carlotta curti Posted March 11, 2023 Share Posted March 11, 2023 Hi, I have been using drip area to fill up an area with drip line irrigation. I have this area , I attached a sketch, where I need to add drip line that contour the area , not horizontal or vertical or diagonal . I tried with the option custom drip area, but I don't think it's working. Thanks irrigation troubleshooting.docx Quote Link to comment
jpccrodrigues Posted March 11, 2023 Share Posted March 11, 2023 Draw the drip line individually, not a drip area. You can offset the arc, select them, create object from shape, drip line outlet and then connect them with secundary pipe. Quote Link to comment
carlotta curti Posted March 12, 2023 Author Share Posted March 12, 2023 Thank you. I have another question. I have difficulty connecting the drip line with the secondary pipe. I have difficulty to select the drip line when I'm running the secondary pipe. The drip line should turn red , but it doesn't. Otherwise the object (drip line) show not to be connected to network. Quote Link to comment
jpccrodrigues Posted March 12, 2023 Share Posted March 12, 2023 The secundary pipe connects the drip line, not the other away around. Design the drip lines and the connect them with the secundary pipe. Quote Link to comment
carlotta curti Posted March 13, 2023 Author Share Posted March 13, 2023 Thank you. Yes, my issue is more general. When I tried to connect the secondary pipe to the drip line I have difficulty because the drip line does not highlight, if it does not highlight it means I can't connect them. It took a while for the drip line to highlight (turning red). Quote Link to comment
