btgroves Posted March 11, 2023 Share Posted March 11, 2023 I am trying to add a Custom Parameter to the CustomParams.txt file and I have successfully located the new location after the update to 2023. I had added some custom parameters in 2022 before updating about 6 months ago, these appear and function just fine. After editing the CustomParams file none of my changes show up on the OIP. Does anyone have any advice or suggestions? Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted March 17, 2023 Vectorworks, Inc Employee Share Posted March 17, 2023 @btgroves Just want to point out that there are better ways now to add extra info to ConnectCAD objects. You can automatically attach your own records and display their values. But you probably know that. We will continue to support the old way but I want to encourage everyone to go towards attached records. Regarding your question, do you want to PM your CustomParams.txt file and the exact steps you took and I'll look into it? Conrad Quote Link to comment
Daniel Dickman Posted March 17, 2023 Share Posted March 17, 2023 @Conrad PreenIs there any harm with us modifying the pre-made records? The record "Device Network Info Record" for example, I would like to add a field for Gateway. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted March 18, 2023 Vectorworks, Inc Employee Share Posted March 18, 2023 @Daniel Dickman No harm at all - they are simply there to show you the way. Conrad 1 Quote Link to comment
btgroves Posted March 20, 2023 Author Share Posted March 20, 2023 @Conrad Preen I was able to solve this issue, we are using custom params as an organization in our workgroup folder but I also had a custom params file in my own Application Support folder on my machine. This was causing a conflict because the two did not match. I do have a follow-up question though, I think for our workflow using Custom Parameters is a preferred method because it does not require the action of attaching a record to every new device as we build out our ConnectCAD device library. Is this feature being considered for removal or no longer supported? I would suggest Custom Parameters features offer a valuable data field for reports and project data. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted March 20, 2023 Vectorworks, Inc Employee Share Posted March 20, 2023 @btgroves We have no plans to remove this feature. However I do urge you to check out Niko's demo of how to use the Data Manager to automatically add any record you like to every new device. You have to scroll down a bit to find it . Maybe you will like this better... 1 Quote Link to comment
