nissim Posted January 9, 2005 Share Posted January 9, 2005 hi i try to install and run minicad 7.0.3 i got an error massage like this "microsoft visual C++ runtime library" "abnormal program termination" is there a incompatebility issue regading XP machine. ?? Quote Link to comment
0 Guest Posted January 9, 2005 Share Posted January 9, 2005 MiniCad is not technically supported under WinXP. However, there are a few things you can check to try and troubleshoot the problem. First, make sure you have a default printer installed. Second, make sure you have QT installed using a custom installation. Third, make sure Explorer is your default browser. There was a known issue when Netscape was the default browser, and certainly mozilla wasn't in the picture durring MC 7 development. With all of that said, the only marked compatible versions of VectorWorks with Win XP are VW 9.5, 10 and 11. You should consider upgrading to take full advantage of what XP has to offer in communication with MiniCAD/VectorWorks. Quote Link to comment
nissim
hi
1 answer to this question
