I am trying to 'properly' set up my plans, elevations and perspectives in Vectorworks 11 with sheet layers and viewports from the plans.
It is not as simple as I thought because it is taking a long time and still the elevations are not very good. I try using the rendering commands and fenestration patterns disappear or all the walls are seen or shadow appears. Should the walls be on layer which is blocked? Do I have to fiddle with the light commands? Which rendering command is best to use?
Or is VW 11 not really very good at this and I should stick to drawing the elevations seperatly or spend more money and upgrade to VW Architect and Render Works?
michael john williams
mw
4 answers to this question
