Piotr Karczewski Posted March 6, 2023 Share Posted March 6, 2023 (edited) Hi, I wanna start a discussion or maybe ask more experienced user or Vectorworks individuals about locking and unlocking plant features connected with plant styles. I do generally understand a policy to introduce and force to use plant styles without an easy option to change most of parameters. But for me and I suppose most of experienced landscape architects disabling plant feature change via OIP is not so comfortable. I give You an example: Firstable in Polish version some of the plants belongs to Polish and some to English class structures (because of translated or non translated libraries), if I would like to unify this I have to edit plant style for EACH ONE species on my design. Secondable if i would like to change "Polygon display", Tag Display, Tag Top and so on I have to do the same - edit each species of the plant on my design. Thirdly, when the feature I need is locked for edition, when I have chosen the plant species and wanna make changes ex. spacing I cannot do that which makes a design process even harder. So I'm asking is there a way to lock/unlock for edition (via OIP) all plant styles features globally? Is there a way predefine my own Plant Tag adjustments possibly to save it in my template? I'm really curios about other users opinion in this matter. Edited March 6, 2023 by Piotr Karczewski Quote Link to comment
Piotr Karczewski Posted March 10, 2023 Author Share Posted March 10, 2023 @Vlado I'll be grateful if You would like to consider this issue. Quote Link to comment
Vectorworks, Inc Employee Vlado Posted March 10, 2023 Vectorworks, Inc Employee Share Posted March 10, 2023 2 hours ago, Piotr Karczewski said: I'll be grateful if You would like to consider this issue. Hi @Piotr Karczewski, thank you for the feedback. At the moment, it's not possible, but the topic is actually active for us, so we'll consider your wishes. 2 Quote Link to comment
AgnieszkaG Posted March 13, 2023 Share Posted March 13, 2023 @Piotr Karczewskiwhich of the plants specifically do you have assigned to foreign, not Polish classes? You can change the plant style settings once as you like and either save this change in the plant directory or create your own library to use in all other files. Then there is no need to constantly change the style settings Now is SP3 available in polish version, please upgrade the program and check classes again. Quote Link to comment
Piotr Karczewski Posted March 13, 2023 Author Share Posted March 13, 2023 On 3/10/2023 at 3:19 PM, Vlado said: Hi @Piotr Karczewski, thank you for the feedback. At the moment, it's not possible, but the topic is actually active for us, so we'll consider your wishes. Thank You @Vlado it'll be awsome to have Plant Tag Styles connected with own template file. It'll be much easier for advanced users to create exact, predefined Plants Styles pattern Globally. greetings! Quote Link to comment
Danilo Posted March 15, 2023 Share Posted March 15, 2023 Thanks for this thread. I have a plant symbol library with over 700 plants in it and I am trying to make the styles uniform. Being able to edit globally would be a godsend! 1 Quote Link to comment
Vectorworks, Inc Employee Vlado Posted March 15, 2023 Vectorworks, Inc Employee Share Posted March 15, 2023 @Danilo there is this power user script function available, that can help you mass edit plant styles in a drawing. It has a UI but it might not be "easy" to use as it's not really a feature, but more a power tool. You can give it a try to see if it will work for you at all, but. be careful as it's not official feature. The plan is to make this a user feature in the future. Make a document script and type in the following VectorScript: MassEditPlantStyle(''); 1 Quote Link to comment
Danilo Posted March 15, 2023 Share Posted March 15, 2023 @Vlado that might be a little advanced for me, but I will give it a try. thanks for the tip. 1 Quote Link to comment
Piotr Karczewski Posted March 23, 2023 Author Share Posted March 23, 2023 On 3/15/2023 at 5:21 PM, Vlado said: @Danilo there is this power user script function available, that can help you mass edit plant styles in a drawing. It has a UI but it might not be "easy" to use as it's not really a feature, but more a power tool. You can give it a try to see if it will work for you at all, but. be careful as it's not official feature. The plan is to make this a user feature in the future. Make a document script and type in the following VectorScript: MassEditPlantStyle(''); Thanks @Vlado! always helpfull! I'll try the script feature. Pleas keep us posted if possible when something will change. Quote Link to comment
Piotr Karczewski Posted December 7, 2023 Author Share Posted December 7, 2023 On 6/27/2023 at 4:10 PM, Katarina Ollikainen said: Hi, this is included in 2023 and I've made a quick video on how to use it. MassEditPlantStyle(''); Hope it helps. Change plant style settings.mp4 On 3/15/2023 at 6:10 PM, Danilo said: @Vlado that might be a little advanced for me, but I will give it a try. thanks for the tip. Hi @Danilo this is a solution provided by @Katarina Ollikainen which @Vlado was talking about. ENYOJ! Quote Link to comment
