Rob87 Posted March 3 Share Posted March 3 Hi there, I have this problem with wrapping a node: SyntaxError Running the node without the wrapper works fine. As I'm not familiar with scripting I have no idea... too bad, a waist of time? I attached the file. As always, thank you very much! Node_syntax_error.vwx Quote Link to comment
Rob87 Posted March 6 Author Share Posted March 6 solved by myself 😇 created a sub-node for every part of the network. In one part, far different of the node dispalyed in the syntax error there was one node causing an error, but replacing it didn't help. I duplicated an existing sub-node and modified it to become like the damaged part. Then it worked. Put everything together and wrapped to new node. Works fine. Quote Link to comment
