bad wall connections
demetris ktorides
Hello!
I wonder if anyone can help. I am doing a scan-to-BIM project and we've surveyed an old house with crooked walls.
I am having issues with the accurate modeling of the walls. The 'wall join tool' is not giving smooth results and I wonder if it's something I am doing wrong or VW gets confused in the joining process with walls that are not square.
I am attaching some screenshots in case someone can help.
(i've used the 'fit walls to objects' tool and fitted them to the roof..)
Thanks,
Demetris
4 answers to this question
This is the way Walls are unfortunately. They will always be flat across their width unless you use a Roof/Roof Face to clip them. So use Fit Wall to Objects command on the gables + at the eaves you will need to clip the Walls with the Roof. Do you know how to do Roof clipping?
