Rob87 Posted March 1, 2023 Share Posted March 1, 2023 Hi folks, searched for this, but couldn't find anything related. But wonder why nobody else needs this. Need: An Alert Information with a string input. The input comes from another node and differs... Need this to inform the user about what is done. F.e. "5 objects modified". 5 will differ and is one part of the string. Thank you! -Rob Quote Link to comment
Letti R Posted March 1, 2023 Share Posted March 1, 2023 Hello, i changed the existing "Alert Inform Dialog", maybe it fits your needs now. To create the node simply replace the whole code of any Marionette node with the code below. @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Alert Inform Dialog' ) this.SetDescription( 'Displays an alert dialog which provides the ' + 'user an information about the result of a ' + 'command. It offers no user choices.' ) #Input Ports input = Marionette.PortIn( None , 'item') input.SetDescription( "input" ) alertTxt = Marionette.PortIn( "" , 'str_alert') alertTxt.SetDescription( "input" ) advTxt = Marionette.PortIn( "" , 'str_advice') advTxt.SetDescription( "input" ) #OIP Controls minorAlrt = Marionette.OIPControl( 'Minor Alert', Marionette.WidgetType.Bool, False) minorAlrt.SetDescription( 'The severity of the alert: minor(true) or major(false)' ) #Output Ports output = Marionette.PortOut('item') output.SetDescription( "output" ) #BEHAVIOR # this.SetListAbsorb() def RunNode(self): #inputs input = self.Params.input.value alertTxt = self.Params.alertTxt.value advTxt = self.Params.advTxt.value minorAlrt = self.Params.minorAlrt.value #script if input is not None: vs.AlertInform(alertTxt, advTxt, minorAlrt); #outputs self.Params.output.value = input To create the string you can just add strings together with the "Str" Node if you put in a list of things (in your case an integer and a string). Regards, Letti 2 Quote Link to comment
Rob87 Posted March 3, 2023 Author Share Posted March 3, 2023 On 3/1/2023 at 6:40 PM, Letti R said: Hello, i changed the existing "Alert Inform Dialog", maybe it fits your needs now. To create the node simply replace the whole code of any Marionette node with the code below. @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Alert Inform Dialog' ) this.SetDescription( 'Displays an alert dialog which provides the ' + 'user an information about the result of a ' + 'command. It offers no user choices.' ) #Input Ports input = Marionette.PortIn( None , 'item') input.SetDescription( "input" ) alertTxt = Marionette.PortIn( "" , 'str_alert') alertTxt.SetDescription( "input" ) advTxt = Marionette.PortIn( "" , 'str_advice') advTxt.SetDescription( "input" ) #OIP Controls minorAlrt = Marionette.OIPControl( 'Minor Alert', Marionette.WidgetType.Bool, False) minorAlrt.SetDescription( 'The severity of the alert: minor(true) or major(false)' ) #Output Ports output = Marionette.PortOut('item') output.SetDescription( "output" ) #BEHAVIOR # this.SetListAbsorb() def RunNode(self): #inputs input = self.Params.input.value alertTxt = self.Params.alertTxt.value advTxt = self.Params.advTxt.value minorAlrt = self.Params.minorAlrt.value #script if input is not None: vs.AlertInform(alertTxt, advTxt, minorAlrt); #outputs self.Params.output.value = input To create the string you can just add strings together with the "Str" Node if you put in a list of things (in your case an integer and a string). Regards, Letti Thank you Letti! Quote Link to comment
