SUMMARY BOX SCALING
sross
Just wondering if the summary box font scaling problem will be addressed any time soon. I use this function and the fonts currently print much too small to be read comfortably. In addition, the position name does not center it self vertically, and extends horizontally outside the gray area of the box if too long. Is there a restriction on the length of a position name to work in the summary boxes??
Thank you
Steve Ross
quote:
Originally posted by sross:
Just wondering if the summary box font scaling problem will be addressed any time soon. I use this function and the fonts currently print much too small to be read comfortably....
What layer scale or scales are you typically working in? Currently the text in the summary box is picked based on layer scale. Obviously in your case it is picking an inappropriate size. If you ungroup the position what is the reported font size of the text? What would you ideally like it to be? (ideally you'd have control over it of course)
The problems with the position name overlap and the text size have been entered in the wish/bug list and will be addressed in a future release. I just took a look at the code for this to see what is going on. Unfortunately because of the way it draws things it isn't a simple quick fix to adjust the size of the text. I will look into whether there is something that can be done short-term to help with this but it looks like it will remain a problem until the next major release.
In Regards to the length of the position name. The formatting for this is set through the menu command "Set Position Label Prefs." It will work on either the selected set of lighting positions or, if no positions are selected, all positions in the document. The length of a position name that will fit in the box will be dependant on the font size you choose.
HTH
Kevin Moore
Product Manager
VectorWorks SpotLight
[This message has been edited by kmoore1 (edited 09-20-2001).]
quote:
I just went over to my current project and tried some experimentation with the 'Position Label Preferences'.
1. The value of Style and Justification do not actually do anything.
2. Values entered here do not match text that is drawn as a trial next to the position label.
Example:
If one position is selected, and the label settings are told to be Tahoma, 14, Bold, Left (Pos Lable Pref menu command). Then use the text tool to create the same text, set the font, size, style as text is usually adjusted. The two don't match.
Regards,
Eric Chenault
Lighting Design
eric@ecld.net
[This message has been edited by Eric Chenault (edited 09-22-2001).]
I'm not able to reproduce this here on either my win or mac machine. Is there any special font or circumstance that I'm missing?
I went through each combination of alignment, style, and justification and it all seemed to match a sample block of text on both platforms. Is the font you're testing with a truetype font? It may be that you're using something like adobe type manager and the previews aren't being generated correctly. Does the text print correctly?
Kevin Moore
Product Manager
Kevin, I was using all True Type fonts on a PC.
Actually, I believe the confusion is that I was using Position Summary with Sum Insts checked as well.
The command works if only the position name is used, but not if a summary box is drawn (by using any Sum checkbox).
Eric Chenault
Lighting Design
eric@ecld.net
[This message has been edited by Eric Chenault (edited 09-28-2001).]
This is the bug that has been plaguing people. The set position label prefs command sets the font attributes for the position name label and all attributes are correctly applied to the position name. The font selected here is used for both the position name label and the summary information but the size and style are overidden for the summary information. This has been buglisted.
Kevin Moore
Product Manager
