JonKoch Posted February 15, 2023 Share Posted February 15, 2023 Hello! I'm attaching my file and a screenshot of the area I'm asking about. After I create the site model, everything looks good but for some reason, on one side, it creates a wall of stacked contours that have returned along the site model boundary. I tried editing the existing contours but they just end up going right back to where they were. I'm sure it's an issue with my source data or some of the settings but any help would be great. Thanks! 743298199_Untitled3.vwx Quote Link to comment
Kevin K Posted February 15, 2023 Share Posted February 15, 2023 @JonKoch You are probably correct that it has to do with your source data. One way to mitigate the issue, if you don't want to mess with your source data is to simply change the shape crop...just slightly move or tweak the shape of the crop in the offending area. Meaning move it in a bit. When you post a file it is a really good idea to note what version of VW it is...I don't use 2023 so I could not open your file 🙂 1 Quote Link to comment
Vectorworks, Inc Employee Katarina Ollikainen Posted February 15, 2023 Vectorworks, Inc Employee Share Posted February 15, 2023 Hi, I created the site model but can't really see an issue. The 'wall' of contours can happen if there is an indent in the source data area - Vectorworks then try to make up the missing area. Try to crop the site just slightly, so it goes right inside the edge of the original contours - this should fix it. 1 Quote Link to comment
JonKoch Posted February 15, 2023 Author Share Posted February 15, 2023 @Katarina Ollikainen @Kevin K Thank you both! The crop seemed to solve the issue. Quote Link to comment
Kevin K Posted February 15, 2023 Share Posted February 15, 2023 @Katarina Ollikainen...Great minds think alike!! 🙂 @JonKoch...glad you solved the issue. 1 Quote Link to comment
JonKoch Posted February 16, 2023 Author Share Posted February 16, 2023 @Kevin K @Katarina Ollikainen One other quick question. If I crop the site model and now it is inside my property bounds, what's the best way to extend those contours out beyond the property line? It's not the end of the world for this particular project but it may be helpful in the future. Thanks! Quote Link to comment
Jeff Prince Posted February 16, 2023 Share Posted February 16, 2023 (edited) @JonKoch one thing you can do is add some point data beyond the “wall of contours” to help vectorworks define the surface beyond the crop. This will smooth the contours out and allow you to show the desired information beyond the property line. You don’t have to add but one or two at the correct elevation to be successful. Edited February 16, 2023 by jeff prince 2 Quote Link to comment
Jeff Prince Posted February 16, 2023 Share Posted February 16, 2023 I created the highlighted 3D loci snapping to a few points near the edge of your site model and then moved them beyond the crop. Copy and paste into place within your site model data and the magic happens 🙂 this image approximates the view you shared earlier. 4 Quote Link to comment
JonKoch Posted February 16, 2023 Author Share Posted February 16, 2023 @jeff princeAwesome thanks. Yeah I'll probably use either some stakes or maybe the open ended site modifier to trace beyond the property line. It's getting pretty fun playing around with this now. What a powerful tool. 2 Quote Link to comment
JonKoch Posted February 16, 2023 Author Share Posted February 16, 2023 @jeff princeYou are a wizard! Thank you! 2 Quote Link to comment
Jeff Prince Posted February 16, 2023 Share Posted February 16, 2023 1 minute ago, JonKoch said: @jeff princeYou are a wizard! Thank you! My pleasure. 1 Quote Link to comment
