Elite Exhibits Posted February 9, 2023 Share Posted February 9, 2023 Question is - ¿ a way to lock the Layer Plane when fly over tool activated ? Is there a way to lock the Layer Plane as "the bottom" - when the Fly Over tool is active as in - There is NO need to look under the foundation / carpet / floor etcetera (as was a setting in the old Export Quicktime VR that VW/RW once had ...) Suggestions are always appreciated ! Peter Quote Link to comment
Andy Broomell Posted February 9, 2023 Share Posted February 9, 2023 My interpretation of your question is that you want the Flyover tool to "stop" at the ground level so that you can't look at the model from a lower vantage point? No, that is not currently possible. The only bit of advice I have is that you can hold Shift while using the Flyover tool, which causes the Z-height of your POV to be locked, and you essentially just orbit around at the same height. 1 Quote Link to comment
Elite Exhibits Posted April 5, 2023 Author Share Posted April 5, 2023 On 2/9/2023 at 11:39 AM, Andy Broomell said: The only bit of advice I have is that you can hold Shift while using the Flyover tool Andy Thanks for the info ... I am still attempting to make in new VW what once was easy with Quicktime VR in older VW ie: A "3D" file that can be sent to a client with the understanding of what they will be able to see. Peter Quote Link to comment
