Hidden Line muddle?
This started in another thread about representing decorative wrought iron.  The modeling and texture creation is fun!
 But the hidden line render causes lines that connect edges which should have no connection.  Strangely, the anomaly is much reduced if the textured object is NURBS surface or NURBS shell (objects on right end of the line).  The NURBS surface and subsequent shell were created from the extrude (Extract tool).
Some things I tried:
  • Change direction of the 2d polys used to clip holes in the original 2d outline shape in the extrudes.  Mirrored about axis, all same direction, mixed, etc. no improvement.
  • HL smoothing angle.  No significant changes at 0°, 0.1°, 1°, 45°, 90°
  • Remove the textures.
  • Remove the stacked objects.
Screenshots show Shaded, HL with 0° smoothing.
File is about 50mb or 40mb zipped, but forum accepted so here if anyone wants to take a look.
Is this just a limit of the HL rendering of narrow volumes?  or is there some correction to be found in modeling or rendering technique?
-B
Rail2.vwx.zip
Edited by Benson Shaw
Reference
  • Like 4
@Kevin McAllister  Thanks, but no difference in the VP.  I tried range of smoothing.
@AlanW  Interesting! Thanks for testing.  I saw same at start of HL render, which is a sort of preview while the HL render bumbles along.  But when the render completes (about 30 to 60 seconds on my rig), the zig zags return.
I edited the extrude to see if any problems there.  Only thing I found was an extra poly at central circular medallion area.  Deleting that made no difference in the HL.
In the Edit Poly pane, I also deleted all the left hand clipping polys and replaced by mirroring the right hand ones.  No change in the HL.
Also tried to remake from that revised poly in a new blank file.  No improvement in the HL.
So, I'm still stumped.
-B
Just to verify - File from @AlanW, when I open it, displays same HL problems in same locations as my original file and at least similar to what all you other responders found. But Alan is only running Windows OS.  Mac/Window difference?  Thanks everyone for testing and commenting!
I will put together a bug report. Could be Win/Mac or my original geometry, or ???.  We should look for it in other files with HL scenes.
Another comment - That HL temporary preview, displays the scene as expected (no anomalies) while the HL render proceeds.  I think it is sort of HL lite or Wire Frame Pro so that one can interrupt the render to make edits to view or geometry without waiting for render to complete.  then start the render again.  I wonder how that preview is different from the completed render, and if it could be a future update feature as additional render mode.
-B
For me too.
As I see the simple Extrudes work fine.
While the NURBS Face thing looks pretty complex to me.
Als I do not know which of VW 3D Modeling offers will finally
bring the best texture mapping result. I see they look quite
different.
Not sure what you mean.  In my views the NURBS objects have fewer lines out of place in HL, seem about same in
HL preview and Shaded.
Wasn't intended as dismissive.  Meant to say he is the only responder running Windows.
-B
I
1 hour ago, line-weight said:
Here's what I get on my mac mini
42 minutes ago, line-weight said:
Hrm... I posted the screenshot above, went away and had my dinner and stuff, then came back to the computer to find it looking like this... so it had maybe not entirely finished doing its render.
Indeed, the first screenshot looks like a raster-based "preview" that is shown while the actual vector-based hidden line render is being calculated.
I never use hidden line in design layers so am unfamiliar with how it works.... it seems the teapot is there for a while, then disappears, but it's not actually finished rendering yet, and there is then a green "Stopping Render" message in the bottom bar...and then at some point that eventually disappears and it's finished.
