Steve Riddle Posted February 3, 2023 Share Posted February 3, 2023 I am having trouble with a landscape plan set where I want levels to be in metres but I need details to be dimensioned in mm. After trying to resolve this problem I converted the file units to mm so I could dimension the details. This has resulted in the site model displaying contours in mm which I need to displayed in m. I expect this would be a common issue and there is a simple solution? Quote Link to comment
0 Jonathan Pickup Posted February 3, 2023 Share Posted February 3, 2023 The way that I would do it is to make metres your main units and millimetres your dual units or secondary units. Then you can set up two dimensions standards. The first dimension standard would use metres and the second dimension standard would be using millimetres. have a look at this movie from 7:30 onwards Quote Link to comment
0 Steve Riddle Posted March 14, 2023 Author Share Posted March 14, 2023 Hi Jonathan, Thanks, I'll have a look into it.🙂 Quote Link to comment
Steve Riddle
2 answers to this question
