In this video I try to use the reshape tool in adjust parallel edges mode to adjust the bottom edge of an extrude to align with to top face of another extrude below, however Vectorworks fails to acquire any snaps on the extrude below. I would expect snap to point to acquire the top corner of the extrude below. I would expect to be able to hit T to constrain the movement to the vertical axis and then be able to snap to the intersect of the constrained line with the top face of the extrude below. I switch to orthogonal mode and rotate view to match the plane of the extrusion hoping that I might pick up a point somewhere but I don't get any snaps at all on the object below. Why is this not working? As you can see I have all my snaps turned on apart from grid snap. I'm not sure if this is a bug or a feature request. But it feels like it must be a bug because if I come out of the extrude and draw a line from the point at which the reshape handle was at to the top face of the extrude below the snaps work as expected. If I then go back into the extrude I'm able to use reshape to edit the polygon inside the extrude to snap to the point at the bottom of the line.
Will
3 answers to this question
