Lolight Posted January 30, 2023 Share Posted January 30, 2023 I have a label legend with 4 user fields, and 3 of them will show in the viewport just fine, but one will not. Is there any reason why just one would be dropping? Quote Link to comment
markdd Posted January 30, 2023 Share Posted January 30, 2023 Is the Class associated with the missing field set to Visible in the Viewport? When you create an extra field after creating a viewport the Class will not be visible unless this function was enabled the last time you opened the Create Class dialog. Quote Link to comment
Lolight Posted January 30, 2023 Author Share Posted January 30, 2023 I created user field 3 and 4 at the same time, and 3 is visible and 4 is not. I guess I am assuming they were the same class, but I will go back and make sure that's the case. Thanks! Quote Link to comment
