Resource Browser is empty
Ivan
I am trying to get the symbol libraires into V10.0.1 The resource browser offers a slide out menu to "Find resourses on Disk'. That path leads to a DB asking for I know not what, at the bottom is a button for 'Set Where" whatever that means and this will get you to a regular folder list where you can choose 'Object Libraiers' to find that all the contents are gray and not selectable.
How do you choose a symbol to add to a new file.
The Help menu starts all descriptions of what to do with a symbol already in the file.
I will bet it is not difficult just hidden in some odd way.
Thanks for the help
Ivan
theholistichome@cablespeed.com
1 answer to this question
Where it says "Files and Folders" in the RB, there is an arrow to the far right. Click on this.
Select "Add New Favorites Files".
An OPEN dialog box pops up.
Go to the VW 10 folder and open the Object Libraries folder. Select the library files you would like to be added to your favorites list and click on choose or Ok.
Do the same for Textures if you have RW installed.
