ben@gibson.co.nz Posted January 29, 2023 Share Posted January 29, 2023 I am having trouble lofting surfaces in 2023. I will draw a nurbs curve and then use the loft tool. rather than following the curve it will simplify it down to something very basic. Below you can see 2 nubs curves and then the resulting lofted surface. Is there a preference I don't know about? it was working fine for me in VW2022 Quote Link to comment
0 Claes Lundstrom Posted January 30, 2023 Share Posted January 30, 2023 What are the settings on Shaded Options? Low? Have you tried something higher? 1 Quote Link to comment
0 Pat Stanford Posted January 30, 2023 Share Posted January 30, 2023 If Claes idea does not help, can you copy and past the loft into a new file and see if it works ok there. If not, please post the file with the loft here so we can take a look. Quote Link to comment
0 ben@gibson.co.nz Posted January 30, 2023 Author Share Posted January 30, 2023 Thanks Pat, I tried Claes's idea. I did have shade set to low but it made no difference when I changed it to high. The loft tool does not seem to work at all if I have more than 2 nurbs curves. test.vwx Quote Link to comment
0 Pat Stanford Posted January 30, 2023 Share Posted January 30, 2023 How did you convert your NURBS curves? When I try with your curves I get the same circular loft. When I make a similar shape to yours starting with a 2D polygon and then convert that to a NURBS and loft those, then it works. Your original curves loft is you draw a connection curve between the two curves and then loft using the 3rd mode of the loft tool, Birail Sweep. I traced over your curve using the Besier mode of the 2D Polyline tool and ended up with a curve with 20 vertices. I then converted that to NURBS and it ended up as a second degree NURBS curve with 20 vertices. Duplicated and lofted in the first mode and it worked fine. I converted your curves from 3rd degree to 2nd degree just by changing the number in the OIP from 3 to 2. They then lofted correctly. When I converted my simplified curves to 3rd degree I got the same circular loft you are getting. I don't have time to figure out what the difference is between 2nd and 3rd degree curves and why that effects lofts right now, but I hope this helps you get what you need out of this. Convert to 2nd Degree and move one. 1 Quote Link to comment
0 Vectorworks, Inc Employee Katarina Ollikainen Posted January 30, 2023 Vectorworks, Inc Employee Share Posted January 30, 2023 Hi, don't know why it doesn't follow the profiles, but if you add a rail, it will work nicely (I assume this is the result you're after?) 2 Quote Link to comment
0 ben@gibson.co.nz Posted January 31, 2023 Author Share Posted January 31, 2023 Thanks that is very helpful. The Nurbs curve was drawn with the NURBS curve tool. Weird that I would need to draw it with a 2D polyline tool and then convert it to nurbs, but that is certainly a solution. Thank you 1 Quote Link to comment
0 Benson Shaw Posted January 31, 2023 Share Posted January 31, 2023 @ben@gibson.co.nz I get same cylindrical loft in your test.vwx file. I wonder if problem is the file itself rather than those curves? Anyway I tested several ways: Deleted all other objects. Moved curves to origin, etc - No joy with Loft no Rail. New NURBS curves of similar shape, same location, or if moved close to drawing origin produce the same result in that file. I did make a proper loft in that file by converting the NURBS to 3d Polys, then convert those to NURBS. Best result, though . . . Copy/Paste in Place the two NURBS curves and into a new blank vwx file. They loft as expected. Loft mystery! -B Quote Link to comment
0 AlanW Posted January 31, 2023 Share Posted January 31, 2023 Hi I there must be something wrong with they were originally drawn. Convert to 3D polys and then back to Nurbs and works fine. Quote Link to comment
0 Claes Lundstrom Posted February 1, 2023 Share Posted February 1, 2023 22 hours ago, AlanW said: Hi I there must be something wrong with they were originally drawn. Convert to 3D polys and then back to Nurbs and works fine. I tried that and yes the shape is correct, sort of, but it's not a generic NURBS surface in the sense that it can be set to any mesh resolution. Quote Link to comment
ben@gibson.co.nz
9 answers to this question
