EFS Posted July 29, 2002 Share Posted July 29, 2002 Is it possible to make the LayerMap Plug-In work with VW 9.5? The script has four lines of errors: Linje #99:SpreadSheet(0.0,0.0,NoRows,NoCols); Linje #107:SprdBorder(false,false,false,true); Linje #113:Hlayer:=nextLayer(Hlayer); Linje #115:END; I have found this Plug-in to be very useful and would like to continue using it with VW 9.5. Quote Link to comment
0 jessepps Posted June 5, 2004 Share Posted June 5, 2004 I am getting the same errors under v10.5.1 and need it badly for a DXF explanation to a client. Quote Link to comment
0 Guest Posted June 6, 2004 Share Posted June 6, 2004 You should post this to the VectorScript section of the MB. Quote Link to comment
0 MullinRJ Posted June 7, 2004 Share Posted June 7, 2004 SprdSheet() is obsolete as of VectorWorks 8.0 SprdBorder() is obsolete as of VectorWorks 9.0 The third and fourth errors are probably linked to the first two. Fix the first two and they may go away. Sorry, I don't know the newer commands to use, but you should be able to find them in the VectorScript Function Reference. You can find the various manuals to download at http://www.nemetschek.net/support/custom/vscript/docs.html HTH, Raymond Quote Link to comment
EFS
Linje #115:END;
3 answers to this question
