Minna Posted January 26, 2023 Share Posted January 26, 2023 Hi! I lost my object info palette in Landmark 2023. If i switch to Fundamedals its there. How can i get it back to Landmark? -Minna Quote Link to comment
0 Ozzie Posted January 26, 2023 Share Posted January 26, 2023 Window / Palettes Quote Link to comment
0 Minna Posted January 26, 2023 Author Share Posted January 26, 2023 3 minutes ago, Ozzie said: Window / Palettes Its there, but I cant find it on my screen..... When I open Fundamentals its there. Quote Link to comment
0 Ozzie Posted January 26, 2023 Share Posted January 26, 2023 In the Menu Bar up to the top Quote Link to comment
0 Minna Posted January 26, 2023 Author Share Posted January 26, 2023 4 minutes ago, Ozzie said: In the Menu Bar up to the top Yes. I do know how to use window->palettes. The problem is that i cant find OIP on my screen even thougt palettes says its there. This happens only in workspace Landmark. If I turn Fundamentals on i can see my OIP. Quote Link to comment
0 Pat Stanford Posted January 26, 2023 Share Posted January 26, 2023 It has probably been moved almost all the way off the screen. If you can find the edge you might be able to drag it back on. Or change your screen resolution to something lower. This will force all the palettes to shift back onto the screen. Once you have it back you can set the resolution back to your preference and rearrange your palettes to fit. 2 Quote Link to comment
0 FlyingHoward Posted January 26, 2023 Share Posted January 26, 2023 Hi @Minna, This may not apply to you so am tossing this out there. Since my SP3 update with VW2023, upon Application startup that the Resource Palette does not always show up at all [Hey Pat, I have looked everywhere on my screens to no avail]. I now need to Un-check the Resource Palette and the Re-check it so that it appears as I have saved it. Might be a bug, have not gone further with this issue yet. M Quote Link to comment
0 Pat Stanford Posted January 26, 2023 Share Posted January 26, 2023 @FlyingHowardI believe that the missing palettes in VW2023 is actually a workspace corruption thing. If it is happening repeatedly, I recommend that you recreate your workspace in VW2023 rather than trying to fix a workspace updated from an earlier version. 1 Quote Link to comment
0 Vectorworks, Inc Employee Payne Chang Posted January 26, 2023 Vectorworks, Inc Employee Share Posted January 26, 2023 6 hours ago, Minna said: Yes. I do know how to use window->palettes. The problem is that i cant find OIP on my screen even thougt palettes says its there. This happens only in workspace Landmark. If I turn Fundamentals on i can see my OIP. Hi @Minna, Can you see the Landmark OIP now? If not, could you post your "Landmark.vww" (if you have one in your user folder, path = "User folder/Workspaces/Landmark.vww") and "User folder/Settings/SavedSettings.xml" so I can investigate? Thanks. Quote Link to comment
Minna
-Minna
8 answers to this question
