Recolor
Landartma
I imported this DWG file from my old software and want to turn it just in to black lines.  I went through and put the symbols and line work on the layers they should be on on one the other is still in imported form.  Is there a way to change everything to B&W line work.  It seems as if the old plant symbols are the only things I can't change.  This is old work from old software but I need this one in VW.
4 answers to this question
1 hour ago, jeff prince said:
Otherwise, you can do it with Class and Attribute control.
Would this always work, also when all Elements are set to Attributes by Object
and when they are deeply hidden behind nested Symbols and Groups ?
By only activating "Use Attributes" in Class Settings (?)
Sure it will.
You might have to go digging into those nested symbols and groups and change some attributes to get a desired behavior...
but such is the penalty for drawing byobject instead of bylayer/class.
