FRED JOHNSON Posted Tuesday at 03:01 PM Share Posted Tuesday at 03:01 PM Gentlemen, I have just upgraded to VWA2023 from VWA2010. I started using VW before viewports, etc. came and have been using VW the old way with layer scales, separate files and so on. I have a standard sheet which I would like to be available for all sheets. How do I get this sheet into VW so that when I place new viewports on a new sheet this sheet can be called up. Thanks for your help. Quote Link to comment
shorter Posted Tuesday at 06:42 PM Share Posted Tuesday at 06:42 PM Use the user or workgroup folder to load your sheet as a resource so that it’s available via the Title Block Border tool in the Dims/Notes toolset. create a template and save that in the user or workgroup folder so that every time you request a new file your sheet template is always available in a fresh empty file. ise the workgroup if you want other team members to get access to the same resources. if it’s just you then user folder will suffice but make sure it’s backed up. Quote Link to comment
FRED JOHNSON Posted Wednesday at 04:29 PM Author Share Posted Wednesday at 04:29 PM Can I just add my logo to an existing sheet style accessible via the title block border tool? that would also work for me. Quote Link to comment
Pat Stanford Posted Wednesday at 05:43 PM Share Posted Wednesday at 05:43 PM Yes, you can take any of the default TBB Styles, convert to Unstyled, then Create Style from Unstyled in the OIP to save it as a new Style. You can then edit the TBB Layout to include your graphics and rearrange to however you want it to look. 1 Quote Link to comment
Andy Broomell Posted Wednesday at 07:04 PM Share Posted Wednesday at 07:04 PM 1 hour ago, Pat Stanford said: Yes, you can take any of the default TBB Styles, convert to Unstyled, then Create Style from Unstyled in the OIP to save it as a new Style. You can then edit the TBB Layout to include your graphics and rearrange to however you want it to look. When making 'new' TBBs from existing, I tend to suggest choosing "Edit Style" then immediately changing the name, then modifying the style as needed. The advantage here is that By Style / By Instance settings are preserved, whereas if you Convert to Unstyled and make a new Style, these have to be determined again from scratch. It also preserves Plug-In Object Style Options (which is perhaps more relevant for other Plug-In Object types, which I also use this process for). Might not matter too match in the OP's particular case (?), but a good habit nonetheless. And of course if you need the original style as well, then it can first be Duplicated in the RM. 3 Quote Link to comment
Elite Exhibits Posted Wednesday at 07:31 PM Share Posted Wednesday at 07:31 PM Andy Thanks much (Also Pat) love the efficiency track on the TBB How To ... Peter Quote Link to comment
shorter Posted Wednesday at 08:54 PM Share Posted Wednesday at 08:54 PM You may find the out of the box TBBs are not sufficient for your needs so it is definitely a good idea to learn how to set them up from scratch. Quote Link to comment
FRED JOHNSON Posted Thursday at 05:12 PM Author Share Posted Thursday at 05:12 PM Thanks Andy and Pat. Quote Link to comment
