Poor text handling in 9.5.2
Jonathan Howard
If I select an existing block of text in VW9.5.2, the edit box opens with all the text transformed into a random new font. Changing it via the text menu has no effect. It can only be re-set by selecting the text box with the pointer, and then changing the font type. I notified this as a problem in 9.5.0, and note it is still present in 9.5.2.
Jonathan mad.gif" border="0
1 answer to this question
I'm not sure it will solve your problem, but my font changing problems were solved after modifying the settings in windows "regional setting" control panel. Try changing the language pop-up menu (rest of the pop-ups and the tabs in this control panel are irelevant to the fonts issue).
