Michael Gilbert Posted January 20, 2023 Share Posted January 20, 2023 That's it. Just want to be able to switch classes as a script so I can add as a menu item. VS just do not get it. Thanks. Quote Link to comment
Pat Stanford Posted January 20, 2023 Share Posted January 20, 2023 So you want a script that can be made into a menu command that will make a specific Class active? Class('Name of your Class'); Take a look at this thread for instructions on how to make a PIO Menu Command and how to add it to your workspace. Instead of the Restore command in the Script Editor in Step 5, use the command at the top of this post, edited to use your proper class name. If this is not what you want, then you will need to give us a better description. Quote Link to comment
