Ben3B Posted January 18, 2023 Share Posted January 18, 2023 Hello I draw a stand for my admiral light, and set up as stand accessory. But in top plan view the stand is over the light, i don't know how I can send it to back 😉   Quote Link to comment
Stefan B. Posted January 18, 2023 Share Posted January 18, 2023 Hey,  Right click and send back or bring forward is you solution. CTRL+B CTRL+F is your shortctcuts. 🙂 Quote Link to comment
Ben3B Posted January 18, 2023 Author Share Posted January 18, 2023 Thanks @Stefan B., but because its an accessory the send to back function doesn't work, the light and the accessory are as one object 😉 Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 18, 2023 Vectorworks, Inc Employee Share Posted January 18, 2023 Try using the 'send to' commands inside the edit accessory dialogue 1 Quote Link to comment
Ben3B Posted January 18, 2023 Author Share Posted January 18, 2023 2 hours ago, jcogdell said: Try using the 'send to' commands inside the edit accessory dialogue Nope it dont work, because in edit accessory mode, I only have the accessory, and because I only have one accessory, I've So nothing to send backward or forward if i ve 2 accessorys I can send one backward or forward.. 2023-01-18 17-47-04.mkv Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 18, 2023 Vectorworks, Inc Employee Share Posted January 18, 2023 Can you share the VWX file? Â Quote Link to comment
Ben3B Posted January 18, 2023 Author Share Posted January 18, 2023 hello here is the link https://drive.google.com/file/d/1DC9DuW8DbUHjR8G5az0Vuc1er_kSVGm4/view?usp=drivesdk @TomWhiteLight  Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 19, 2023 Vectorworks, Inc Employee Share Posted January 19, 2023 OK, So I have tried this a number of ways using your content and also Vectorworks Stock Content. It looks to be a case of works as designed. Â What we are seeing are expected outcomes. So a couple of things... I will make an enhancement request to enable stacking order within edit accessories, For now your options are... Option 1 - Customise the 2d components to 'Clip Surface' the middle of the stand (Screenshot attached). Â Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 19, 2023 Vectorworks, Inc Employee Share Posted January 19, 2023 Option 2 1. duplicate the stand and remove the accessory record. 2. Insert the stand as a hybrid object, Make it a hanging position and insert the lighting device. 3. (Optional) Create a Schematic View of the HP 4. Select all objects and create a symbol with convert to group enabled.  You have now mad a light on a stand with a schematic view that you can click to insert into your document and simply replace lighting device for a different fixture.  Quote Link to comment
Ben3B Posted January 19, 2023 Author Share Posted January 19, 2023 Hello thanks for answer 1 hour ago, TomWhiteLight said: It looks to be a case of works as designed. Ok but why it doesn't happen with clamp ? Your option 1 looks good 😉 My problem doesn't happen with clamp because they don't have 2d component ...   but your option 2, I did it in past without the hanging position so it didn't work and I wasn't able to edit fixture's pan and tilt ... But your method is ok, and maybe quicker than mine, but I need as many symbol as stand I can use 😉 1 Quote Link to comment
