Peter Vandewalle Posted January 13, 2023 Share Posted January 13, 2023 I'm trying to get a handle to a selected object in a wall. When I select a PIO object in a wall (in this case a pilaster) and I run this script: def apply_code_to_objects(hObj): vs.AlrtDialog(f"Obj: {vs.GetTypeN(hObj)} in {vs.GetTypeN(vs.GetParent(hObj))}") vs.ForEachObject(apply_code_to_objects, "(INSYMBOL & INOBJECT & NOTINDLVP & NOTINREFDLVP & (VSEL=TRUE))") I get "Obj: 68 in 31", where 68 is wall and 31 is a design layer. I can't find a way to get a handle to the selected pilaster though... Any ideas? Quote Link to comment
twk Posted January 13, 2023 Share Posted January 13, 2023 you'd have to do a deep search, for objects within the wall: try this: def apply_code_to_objects(hObj): object_type = vs.GetTypeN(hObj) object_parent_type = vs.GetTypeN(vs.GetParent(hObj)) if object_type == 68: # Check if object is a wall, search within wall h2 = vs.FIn3D(hObj) # Get handle to first object within the wall object using FIn3D while h2 != None: if vs.Selected(h2): # If object within is selected if vs.GetTypeN(h2) in [86]: #If type is plugin object (86 = Plugin Object) object_type = vs.GetTypeN(h2) # store object_type as vs.GetTypeN of this selected object within the wall break # break while loop h2 = vs.NextObj(h2) # else move onto next object within wall vs.AlrtDialog(f"Obj: {object_type} in {object_parent_type}") vs.ForEachObject(apply_code_to_objects, "(INSYMBOL & INOBJECT & NOTINDLVP & NOTINREFDLVP & (VSEL=TRUE))") 3 Quote Link to comment
