Wood Posted January 12, 2023 Share Posted January 12, 2023 Hi, I use a modified hoist symbol to represent our End of Truss locations to export for our layout X/Y information. I also use a similar symbol to represent other points of interest that we want to mark on the floor. I have removed all of the load data, and put them in a separate layer so they don't actually connect to the truss. (So braceworks doesn't try to calculate them). I then have a worksheet that pulls all hoist symbols and exports their X, Y etc for output to my label and layout system. In 2023, they've started autogenerating Bridles. I can't seem to find a setting to disable this. Unadulterated hoist symbols do not generate the bridle. What am I missing? While we're on the topic, is there a better way to do this? Quote Link to comment
PatW Posted January 12, 2023 Share Posted January 12, 2023 (edited) There is a auto compensation if you exceed the maximum chainlength of the hoist. A possible workaround is to change the chainlength( = maxchainlength) recordfield in the hoists symboldefinition then you need to replace the symbol of the hoist by the same in order trigger a refresh of the chainlength. Edited January 12, 2023 by PatW Quote Link to comment
Wood Posted January 12, 2023 Author Share Posted January 12, 2023 7 minutes ago, PatW said: There is a auto compensation if you exceed the maximum chainlength of the hoist. Hmmm, seems like a plausible source, but I the hoist inserting at 0", and high hook height at 0". Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 13, 2023 Vectorworks, Inc Employee Share Posted January 13, 2023 If @PatW's suggestion doesn't work can you DM me the file so i can see if I can figure out what is going on? Quote Link to comment
