marc12386 Posted January 8, 2023 Share Posted January 8, 2023 Hi, how do I fix the issue that I'm having in the images bellow? everything is supposed to be black. Quote Link to comment
ASalien Posted January 9, 2023 Share Posted January 9, 2023 In the Document Prefrences, you should be able to uncheck "render normals": 1 Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted January 9, 2023 Vectorworks, Inc Employee Share Posted January 9, 2023 Yup, @ASalien got it! You may need to ensure your document preference dialog is in "advanced" mode to uncheck the box. But, I believe you had to already be in advanced mode to check it in the first place 😄 Hope these posts have helped you! Quote Link to comment
marc12386 Posted January 10, 2023 Author Share Posted January 10, 2023 Okay cool but its isnt outputting light but my tilt and pan is working. Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted January 10, 2023 Vectorworks, Inc Employee Share Posted January 10, 2023 It is odd that your pan and tilt would be working over DMX but the dimmer would not. I would try your best to make sure you are using the proper fixture personalities/modes in both Vision and the light console as this is the most likely cause. If you continue running into issues, you can contact VW Technical Support or might be able to post your VSN here. If we can reproduce the issue in-house, we should be able to fix the code or content. Quote Link to comment
