I am new to site work on Vectorworks. I got the survey in AutoCAD form, made sure the scale was right and imported into my model. I was then able to make the topo. However now the topo will not show correctly when in isometric views. The screen shot is the left view and you can see my building in the lower left corner. The layer is set to the building layer. When I set the layer to the topo layer, the topo shows correctly and the building doesn't. What am I missing? Update: I found the solution, I put the topo on the building layer and it showed up and was at the wrong elevation!
jmhanby
found solution
3 answers to this question
