White Halo in Image Props without background or White background
erminio
Hi everyone
I have to submit a question about an annoying white halo appearing in image props, when rendered without a sky background for photo insertions pourpose
As in the linked image, when a colored background is applied, the white halo disappears, so it isn't a matter of alpha quality
This problem started with Vectorworks 2022 and has not been solved yet
I've done dozens of tests with similar results
No matter the quality of the starting image nor the render type or quality
Maybe I'm wrong but I've not seen previous posts matching this problem
Any help will be appreciated
Thank you for your time
15 answers to this question
Unless I am misunderstanding your issue, It works fine when you use good quality image props....
The testtrees.PNG was created using "export image" from a sheet viewport.
screenshot....png is a screen shot of the same.
testtrees-affinityphoto.png was created by opening testtrees.png and inserting a black background.
RGB items are simple extrudes the white "background" is nothing, just the typical vectorworks environment.
567917376_ScreenShot2023-01-06at12_50_58.thumb.png.f7c3a8da036a7a1f5d49432d1b4c3621.png
Edited by jeff prince
Thank you for your interest Jeff
Let me understand: are trees rendered Image props or simple PNG?
Which Vectorworks release have you got? If 2022 or later could you please attach your file?
As I wrote, the problem is not the quality of the image, since the same image props worked fine till Vectorworks 2021
For a period I had to work with 2022 and finally export in 2021 for final rendering, but now I don't have 2021 installed any longer
I'm attaching my test file in 2022 version, created in 2023 and exported
You can also find the original PNG image
Image Props Render v2022.vwx
The trees are built in vectorworks trees composed of imageprops
That was made in V2023, I still have V2021 & 22 installed too.
I opened your file in 2022 and updated the viewports.  Everything looks normal to me without changing any of your settings...
277039542_ScreenShot2023-01-06at15_07_42.thumb.png.02e1d1e99540069a07fb640da682d214.png
tree test.vwx
  • Like 3
Thank you Jeff
This is really weird
Have you seen the white halo before re-rendering that?
I've put a magenta rectangle back in your viewport and everything was good
I've re-rendered the same VP with no changes and got the usual white halo again
Just one thing
I see you've got also Vectorworks 2023
Do you encounter the same halo in 2023?
3 hours ago, erminio said:
Just one thing
I have not experienced this problem in any version.  Have you searched these forums for similar problems?  I wish I could help you, perhaps a call to tech support is in order?
Thank you Jeff
It seems that no others is experiencing that problem
This is even more weird
I'm just wondering two last things that could differ
1  I own an italian release
I've sent a file with a description of the problem last year to italian distributor
I think they've sent to NNA
2  I'm working on a silicon mac
Passing from an Intel, work is faster, but less stable in my opinion
Posted (edited)
14 hours ago, rDesign said:
I found another thread which describes a similar issue, perhaps this is the one @zoomer was trying to recall?
It’s strange that the appearance of the white halo is not consistent. I would send in your file to tech support.
Thank you rDesign
This gave me more tests to try
I tried to uncheck the option "None fill uses alpha transparency" suggested by Panzer, but didn't solve
Neither solved removing reflection from the image prop suggested by zoomer
Is this post enough to start a bug ticket?
Edited by erminio
Posted (edited)
Point 2 is the answer!
I have installed Vectorworks 2023 on the "old" iMac with the same Ventura OS and the halo disappears
So it really seems to be a question linked to Arm processors
Edited by erminio
  • Like 3
Thank you Kevin
Didn't know this trick!
However I do need a VP without background in order to make a post production in Affinity Photo
I think that if you re-render this VP you'll see the halo disappear, since you have an Intel based Macimage.png.e89f9d07a98e197d2494891a25ca719e.png
